K&N CAI KIT
K&N CAI KIT
Has anyone purchased a K&N Cold Air Intake Kit? I purchased one and was all set for install but had a fairly major problem. The main Intake tube was molded plastic instead of the flexible ducting on the OEM tube. Where this presents a problem was I was able to install the system correctly but not close the hood. The air filter assembly heat shield did not fit in the OEM lower air filter housing. I followed directions even double, triple checked to make sure I wasn't missing anything. The intake tubing has three sections, one from air filter and the other two sections towards throttle body one curving underneath. Instructions and packaging clearly indicate compatible with 2015 + Expedition and Navigator 3.5 E/B?
I returned pending further review but looking for input.
AmericanIron460
18
10-19-2015 01:25 PM
76fordf100
26
11-20-2004 08:09 PM
