7.3 4R100 won't shift - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-03-2018, 11:55 AM
vicp21's Avatar
vicp21
vicp21 is offline
vicp21 is starting off with a positive reputation.
Would a bad speed sensor cause the speedometer to bounce around erratically? The trans is also not shifting higher than 2nd gear and the OD light is flashing on the shifter.
Old 07-03-2018, 12:19 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
What codes are stored in the PCM? That will give a great place to start.
If you're into the guessing at what part to replace game, I'd start with the vehicle speed sensor on the rear differential. That could cause both problems.
Old 07-03-2018, 09:51 PM
vicp21's Avatar
vicp21
vicp21 is offline
I'll see if I can grab some. A code isn't going to tell me why the speedo is bouncing around though.
Old 07-04-2018, 08:12 AM
Mark Kovalsky
Why not? There are codes for that.
Old 07-05-2018, 04:35 PM
Clubwagon's Avatar
Clubwagon
Clubwagon is online now
Clubwagon is gaining momentum as a positive member of FTE.Clubwagon is gaining momentum as a positive member of FTE.
^^^ What he said.
If the OD light is flashing there is a transmission code set. Could easily be a VSS. If its full of metal it could be reading erratically.
Old 07-09-2018, 11:19 AM
vicp21's Avatar
vicp21
vicp21 is offline
Sorry guys, I've been on vacation. I'm going to start it up today and see what codes I can grab. The VSS seems to be most likely the culprit. It ran fine the week before this started. Is there any way to check the VSS for functionality in case it ends up being a wiring issue?
Old 07-09-2018, 08:47 PM
vicp21's Avatar
vicp21
vicp21 is offline
So I got 3 abs codes and I think this last one is it. Nothing else came up when I checked.
Old 07-10-2018, 09:47 AM
Clubwagon's Avatar
Clubwagon
An E350 with a 7.3 likely has a single VSS on the diff housing. Pull it and see if its got a bunch of debris stuck to it. If so, clean it off with a clean cloth and re-install, clear the codes and test drive. If the codes come back replace the sensor.
If the sensor doesn't have much of anything stuck to it, replace it, clear codes and test drive.
Good Luck.
Old 07-10-2018, 11:19 AM
vicp21's Avatar
vicp21
vicp21 is offline
I hope there's not debris lol then I've got bigger issues.
Old 07-10-2018, 02:34 PM
Clubwagon's Avatar
Clubwagon
Maybe, maybe not. I have seen fouled VSS's come out of rear ends that were just fine. LSD clutches are notorious for creating the fine metal that feels like grease and fouls the sensors.
If you have a christmas tree with shards, that's a problem
Old 07-12-2018, 08:36 AM
vicp21's Avatar
vicp21
vicp21 is offline
Didn't look to dirty. I wiped it off and put it back in. Pulled out of the driveway and the speedo worked fine for a few secs then dropped off to zero. So still no signal.
Old 07-12-2018, 09:43 AM
Clubwagon's Avatar
Clubwagon
That looks normal. Replace it. Most likely a bad VSS. I replaced VSSs in my vans, it seemed, every few years.
Old 07-12-2018, 09:48 AM
vicp21's Avatar
vicp21
vicp21 is offline
Every few years? What brand do you use?
Old 07-12-2018, 09:52 AM
Clubwagon's Avatar
Clubwagon
The OE units lasted for several years and well over 100K miles. I used the vans exclusively for long distance towing. Consequently, it seemed I always had a VSS failure on the road, a long way from home. I would end up changing the VSS in an autoparts store parking lot. So it was whatever brand the parts store I found off the interstate had.
Old 07-17-2018, 08:34 PM
vicp21's Avatar
vicp21
vicp21 is offline
I replaced it, but it's still not working. The connector is missing a tab so maybe it's loose somehow? Seemed like it would still have some type of signal.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
