7.3 4R100 won't shift - Page 2 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-18-2018, 07:18 PM
vicp21's Avatar
vicp21
vicp21 is offline
vicp21 is starting off with a positive reputation.
So I exchanged that sensor and it still doesn't work. I have 5v at the connector. I noticed that my odometer and trip meter didn't move at all so I checked on the trans and found this. I'd like to fix this wiring mess. Where are they going? Under the dash or the hood?
Old 07-19-2018, 08:29 PM
Clubwagon's Avatar
Clubwagon
Clubwagon is offline
Clubwagon is gaining momentum as a positive member of FTE.Clubwagon is gaining momentum as a positive member of FTE.
You should be able to find a schematic online somewhere. Pretty sure the VSS runs to the PSOM on the back of the instrument cluster.
Old 07-19-2018, 10:35 PM
vicp21's Avatar
vicp21
vicp21 is offline
It's a 2000 diesel with mechanical odometer, if that makes a difference. The connector on the tail of the trans has 2.8v going to it. As crappy as the wiring looks I don't think that's the problem. I do need to replace that connector though. I have a 4x4 trans I might be able to try a sensor from assuming they use the same one.
Old 07-20-2018, 10:56 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
The vehicle speed sensor is on the rear differential, not on the transmission. The speed sensor on the rear of the transmission is the output speed sensor. The 4x4 uses a different sensor, they are not interchangeable.
Old 07-20-2018, 11:46 AM
vicp21's Avatar
vicp21
vicp21 is offline
Ok thanks. Is there an input speed sensor on the trans too? I don't suppose there's a way to test these sensors is there Mark?
Old 07-20-2018, 10:23 PM
Mark Kovalsky
There is an input and output sensor on the transmission. They are both on top of the trans, one near the front and one near the rear.
You can check each sensor for resistance. Somewhere around here is the ohm value that you should get.
Nothing that either the input or output sensor does can make the speedo bounce. The vehicle speed sensor can do that.
Old Yesterday, 06:45 PM
vicp21's Avatar
vicp21
vicp21 is offline
I put a new vss in it. There was like 5v going to the vss.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
