Factory upgrades from the junkyard...
#31
Has anyone mentioned the dome light mod? Replace the early style chrome dome light with the 96+ dome light. Direct swap, much brighter dome light, looks more modern, and doesn't heat up to 1000°F when it's on. Plus there are tons in the junkyards. I just did it recently in my own truck.
They were in 1995 model years too.
The one thing that I find that is a little off though is, on a standard cab truck,the light beam aims much higher than it does on Bronco/S or Crw cabs due to the angled roof section that it mounts to.
Not a terribly big deal.
And bucket seats didn't come in standard cab trucks except Lightnings. We had this discussion fairly recently here.
#32
#33
Intermittent wipers are an easy upgrade, also used to get the drl modules off the Canadian trucks and it was plug and play. I once found a truck that had the "Northwest Package" with an oem factory rear defrost back glass. Have never seen another. The locking hood latches were also a popular add-on.
#35
Are you referring to a 40/20/40 seat?:
https://www.ford-trucks.com/forums/1...l#post13333670
#38
#39
#40
Broncos had skid plates for the transfer case and fuel tank. The bronco tank is a 25 or 33 gallon model, and much taller than the f series rear tank.
be leary of any transfer case skid that has a bend in it. It's either been bashed on a rock or they used it as a jacking point. Either way diminishes the integrity of the skid.
#41
is the newer one an easy swap?
#42
Just in case you can't find what you are looking for this site can really help. You can search your local area with it too. I've found a couple of parts yards around here that I didn't even know existed. Good luck!
Car-Part.com--Used Auto Parts Market
#43
#44
This is a little embarrassing, since I used to be into autocross with a modified CRX, but I didn't realize that my truck lacked sway bars. So I went by the Pull-a-Part this morning, and found a '93 XLT with front and rear bars... sadly I didn't have anything with me large enough to take the spring perch off. Any idea what size that is off the top of your head? I'm hoping if I take off the front plate, sway bar, and end-links as one piece... that they'll only charge me for one item. If someone gets to it before I can return, I did see a '91 Bronco with the front bar still in place. Funny thing is, I saw (weeks ago) a '95 XL that had the front "skid plate" that the sway bar attaches to, I can't say if it had a sway bar then, since I wasn't looking... but I remember thinking that I was pretty sure my truck didn't have a similar plate. I have a pile of ball joints and tie rod ends that I need to install on my truck, I'd like to get the sway bar from the Pull-a-Part so that I can do them all at the same time!
#45
