2003 f250 powerstroke 7.3L wont start - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 07-09-2018, 06:16 PM
Blaisegravoisjr
Blaisegravoisjr is offline
Blaisegravoisjr is starting off with a positive reputation.
Originally Posted by Blaisegravoisjr View Post
Gpr reads 12.5 on passenger side nut with key off and with key on the driver side nut doesn't read anything.
i was told how to bypass this but still didn't work. Truck still turns over but don't start
Old 07-09-2018, 07:10 PM
Blaisegravoisjr
Fixing to replace GPR and see if that works
Old 07-09-2018, 07:35 PM
Walleye Hunter
Walleye Hunter is online now
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
Just throwing parts at it gets expensive. I recommend that you take the time and troubleshoot. There are four wires on the GPR. Front one should have power when key is on, the rear one grounds through the PCM and the PCM grounds it when glow plugs are called for. Remove the rear wire on the GPR (the lead to the PCM) then ground the GPR at that lug while the key is on and see if the GPR works. You can hear it click when it activates. Then once you have it activated check the right hand lug for voltage.
Old 07-10-2018, 07:11 AM
DogRidesInBack's Avatar
DogRidesInBack
DogRidesInBack is offline
DogRidesInBack is gaining momentum as a positive member of FTE.DogRidesInBack is gaining momentum as a positive member of FTE.
Thanks for posting this. I had it wrong in my post 15. I have edited my post to refer readers to your post.
And to the OP... It only takes a couple minutes to troubleshoot the GPR, about 20 minutes to swap it. The least expensive quality GPR if you do swap is the GPR-109 from NAPA. The lugs on the top are clocked 1/4 turn from stock but the wires do reach the right locations.
The NAPA GPR-110 is the "stock" replacement and cost is at least double. Then the dealer for true OEM or the IH part at yet more $$$. The Standcor relay is considered the upgrade around here.
I put a GPR-109 in mine. Remember to remove the ground lugs from your batteries before doing a swap, that first big lug is always hot and has a lot of amps available.
Old 07-13-2018, 06:49 PM
Blaisegravoisjr
I am not getting power to fuel pump. Is there a relay or something the fuse in #40 has power but not the fuelift pump
Old 07-13-2018, 06:58 PM
Blaisegravoisjr
Don't have power to the fuel shut off switch also
Old 07-14-2018, 07:55 AM
HD Rider's Avatar
HD Rider
HD Rider is offline
HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.
Check all fuses. The fuel pump will only run for about twenty seconds when the key is turned on so you need to be quick or get a helper to check for power.
Old 07-14-2018, 11:22 AM
BBslider001's Avatar
BBslider001
BBslider001 is online now
BBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud of
Google the no-start chart and quit throwing parts at it! These trucks are fairly easy to diagnose if you follow a plan, not to meniton there are 1,000,000 no-start threads with all of this information. I get being new, but look at the stickies as well. Get a code reader that works....and again, look up the no-start flow chart for the 7.3. Our guess is as good as yours without any codes or pertinent information.
Old 07-15-2018, 08:47 AM
Walleye Hunter
I thought that it was fuse #30 that ran the pump.
Old 07-15-2018, 03:38 PM
HD Rider's Avatar
HD Rider
HD Rider is offline
Fuse #30 runs the PCM.
Old 07-15-2018, 05:07 PM
Walleye Hunter
Doh, that's right, PCM and fuel bowl heater.
Blaisegravoisjr
1999 to 2016 Super Duty
07-02-2018 01:46 PM
millwrightbrian
02-18-2015 03:27 AM
robbyf250
08-15-2010 09:26 PM
mantecans
05-08-2010 07:32 PM
explorerdad
09-05-2001 06:39 PM
Quick Reply: 2003 f250 powerstroke 7.3L wont start
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
