Proper towing practices to reduce transmission heat?
#62
#63
Anyway, lockup is something to investigate as it will reduce heat creation. From a separate issue I have been looking at, I would install an interlock from the IVS (Idle Validation Sensor(?)) on the throttle to remove lockup when the engine is at idle. Would not want to stall the engine at idle when stopped because the TC is locked. [Apologies if I goobered the sensor name, there is a sensor to detect when the throttle is not depressed, that's the one I mean]
As a possibly useful datapoint, when climbing my mountain with no payload, I'm spinning 2,200 to 2,500 RPM in 2HI at 10 to 15 MPH, transmission set to D, not sure what gear the transmission is actually in.
#64
#65
From actual measurements, I can tell you that you are 100% wrong. When the torque converter is unlocked and the truck is working hard the torque converter creates FAR more heat than the pump does. It's not even in the same state, much less in the ballpark.
#66
I need to learn more about the function of the Torque Converter, when the Torque Converter locks up, and what causes it to lock up on these 4R100's. Any input or reading material on this subject appreciated.......
#67
Sjbj... After rereading your post and more understanding the scope of your question, it appears to me that you are at information overload.
Your original question was learning more about towing techniques. One question that was not asked ,the distance and the weight you are pulling, if it was asked I didn't see it.
I think the distance and weight is crucial to the answer to your question.
It appears your getting technical information to a problem that doesn't exist... Imo
#68
#69
#71
I will have to read up more on this TC lockup switch, however, I'd be scared I could be doing more harm than good (not knowing enough about these transmissions to know when it would be good to use the switch and when not to). Again, I'd have to educate myself more on the subject. But I guess that is the beauty of this site, to find out from others who know and have experience.
#72
Back to the original question at hand. I did mention somewhere in the thread that I was towing my 5th wheel toy hauler (exact weight loaded I'm not sure, but dry weight is close to 9k and trailer loaded is rated up to 14k but I don't think I'm at max at 14k). Truck has a small lift while rolling 34's. So I know that doesn't help my towing. The road I'm traveling to camp site is a steady grade up a mountain dirt road guessing 2-4 miles. It is slow going with the trailer attached. It sounds like the general consensus is to put it in 4x4 Low, leave gear selector in Drive and go. Since I really don't need the front hubs locked (unless I encounter slipping of traction), I think I'm going to try the disconnecting the ESOF connector to try the low gear but maybe save a little stress on the front hubs if not needed.
So I have received my answer from the helpful crew on this forum as to the "best" method to tow my trailer in this particular situation. This way I now know how to do my part (and not add to the problem), and hopefully my truck will do its part with no further issues. I will report back on my experience after the next trip.
#73
I do have one question for you experts or more experienced out there. Hopefully to learn from my mistakes. Last year when I towed my truck twice up the same hill (once with no temperature issues to note, and the 2nd time when my transmission overheated and ultimately had to be rebuilt). If memory serves me correct, I believe I dropped the gear shifter into 2nd on that 2nd trip (left in D on 1st trip). Was that my fatal flaw? Potentially stuck in wrong gear and caused it to overheat? Too high of gear towing that heavy load up the grade? Instead of staying in Drive and letting it find where it wanted to be?
#74
I keep my ESOF vacuum line loose with a .20 or .22 cal air rifle pellet stuck in the soft vac elbow. I use 2wd low moving the trailer slowly this way more often than i need to have esof 4x4 high or low and it takes only a few seconds to pop the hood pull the pellet and place the rubber elbow back onto the solenoid or just leave in this configuration and turn the hubs manually.
#75
Since you are a transmission engineer, I will take your word for it. Thanks for being a member of this forum.
