5.0 in 65 NEED FORMED RAD HOSES
Installed the 1989 5.0 ( FI replaced with carb ) into the 65 years ago, During to time constraints then I used the universal upper & lower hoses, and at the same time I went to the 90 degree thermostat housing.
NOW, I would like to replace the universal hoses for FORMED ones.
I'm sure there a MANY on here have done this swap and may have the hose part numbers handy.
ANY help appreciated.
BTW, at the time I also got aluminum 1965 replacement radiator, from my understanding at the time it was identical.
I would drive your truck to your local NAPA (or whoever you normally use), and ask to see hoses for a bumpside with a 302, hopefully they'll let you take them out to the parking lot to compare & see if they'll work for you.......
And if not, they might allow you peruse their hose rack in the back so you can see if any others look viable.
James
James
Time consuming for workers & customers
James
James
Goodyear: 60967 upper
Goodyear: 60995 lower
Gates: 20860
Gates: 21053
Thermostat Style ? My top Rad is 1 3/4
Installed 66 radiator in my 65 so the size of the inlet and outlet possibly different? Also, may find it difficult to compare these particular brands in local auto parts store, suggest inquire in advance or have them check for appropriate cross reference and compare. The upper radiator hose is on the passenger's side, and the lower hose is on the driver's side.
Gates: 20860
Gates: 21053
Gates: 20860
Gates: 21053
triumph1200
1947 and Older Ford Trucks
05-24-2017 05:08 PM
john fin
22
04-13-2012 09:39 PM
scf100
03-30-2005 11:37 AM
