Recovery/ tow tools for pulling someone out of mud/sand
A 2WD stuck in gravel was the title of this thread? You could actually use a full chain in this unique scenario. You're trying to tell someone who presumably doesn’t have any experience with this situation to carry around several setups and make a judgement call on which one to use? Just don’t hook the ****** strap to the tail pipe and it’ll be ok.
Yes, pulling a stuck vehicle out of gravel is nearly exactly what the OP said in the title, and fits perfectly with the question OP posted. What gear would I need for pulling someone out of mud/sand (gravel surely counts, and it doesn’t matter if the stuck vehicle is 1, 2, or 4 wheel drive if you are still interested in helping someone).
You are also advocating to use a full 30 foot chain now? Quote - you could actually use a full chain in this unique scenario - unquote. Interesting turn around from your previous comment of don’t use a chain. I recommend against using a full 30 ft chain if you can avoid it, but I recognize your comment that it can be done.
It also appears that you do not recommend carrying several different tools to help match the tool to the recovery. A ****** strap certainly works well in some conditions. It’s kind of the hammer of recovery gear. Even when a screw driver or multimeter would be a better tool, a hammer can sometimes get the job done. Kind of a “hold my beer” tool (to use HRTKDs point). They work great in mud and sand when there are solid anchor points, yes. They are pretty poor, though, when careful control is required or maneuvering room is restricted.
For the OP, I appreciate your question, and there are several good answers in this thread (with more to come, I’m sure). Research each component on your own to make sure each is right for your needs, and go out there and have fun!
CU - thanks for your comments. Also, congrats on the recent purchase of your new 350 and recently joining the forum. Welcome!
In my exxpereince, all I've ever needed is a stout recovery strap, some D rings, and a strong light you can point. Its almost always getting dark by the time someone calls for help, so the light usually helps quite a bit.
This is a great strap that comes with D-rings and has a nice, tidy case to put it all in. The Max Tracks are amazing in mud and sand, but we usually only take those to long Baja trips where there's really no other option than get yourself out or abandon ship.
There are some good suggestions here BUT USING A CHAIN ISN'T ONE OF THEM I say this from a nearly deadly experience with using a chain for a recovery attempt...Chain was just long enough that when it broke close to the hitch on my truck it whipped back went through the back glass right next to my buddy's wife's head..
Get a quality JERK strap and a couple Crosby brand shackles to match the capability of the strap.
safe? Well, for a low stress pull maybe, but for a full power pull of a stuck vehicle, there are numerous stories of trailer ***** snapping off and the tow strap going through the window of the towed vehicle. Either limit the stress, or pull the ball mount completely out and shove the tow strap loop into the 2” receiver and secure it with the draw bar pin.
Received 6,629 Likes
on
I've used the ball before but one of these (tow strap mount) is likely better to use. I also use the safety chain mounting points and a D-ring. One other thing that some folks learn the hard way, the tow hooks on the front of the truck should be used when recovering your vehicle, not someone else. In general, you don't want to be pulling in reverse when in 4Hi or 4Lo. I don't know how tough the front differential is on the Superduty, but in 1/2 ton trucks I've seen the differential get destroyed by a reverse pull in 4Lo.
On a side note ..... I get amused when I see F250/350 size vehicles riding around with 5-6000 lb ball mounts. Certainly OK for if they are only hauling small trailers or boats .... But
So I got Rhino shackles for the front and a Curt shackle Receiver for the back( Curt was the only one I could find that had a 2 1/2” receiver.)
I haven’t bought the recovery strap yet, but was leaning to the Rhino. Any others I should look into?
Besides price and the obvious, are there any downsides to a 30’ over 20’ rope?
on
#28
I understand and that makes sense.
#29
A chain is fine to use, if you know how to use one properly. In my 15 years of fourwheeling, a chain is all I have used. I just bought my first ****** strap this past winter.
Now, I'm not saying for every newbie to run out and grab a Home Depot "5/16 tow chain" and have at it....
Chain, straps, mats, winches, etc...are all tools. Use the best tool for the job, and get educated in how to use those tools.
#30
As others have said, it's all how you use the tools at your disposal. Personally, I'm not a fan of anything that involves snatching or jerking a vehicle. We had a soldier at a FOB get killed in Iraq when some guys with a chain thought they could ****** a stuck semi out of pea gravel. They lacked the wisdom and experience to know what could go wrong and a guy observing off to the side (actually a very long way) took a broken chain link to the head.
My preferred tool is a winch since it is slow and very controllable and I'll tie off to another vehicle or solid object, but that may not be an option in the middle of a sand dune. Spend a few minutes on youtube watching "off road recovery fails". At a minimum, it could be slightly educational.
Even winching has it's hazards which is why I've gone to synthetic rope on my winch equipped vehicles. I've broke 4 steel winch cables on a smaller bulldozer nearly 25 summers ago. Probably about 5/8 to 3/4 of an inch in diameter. If it wasn't for the cage around the driver, I wouldn't be typing this post....
