Replacing rear tank 1997 f350 4x4 460
Just picked up the truck and the previous owner says the rear pump has not worked in years. The whole truck has been neglected so I am thinking of just replacing the tank. I found this set at rock auto https://www.rockauto.com/en/catalog/ford,1997,f350,7.5l+v8,1127102,fuel+&+air,fuel+tan k+&+pump+assembly,17130 . Is there anything else I will need to tackle this or is this everything so that I will have two working tanks?
Anyone who's never worked with fuel/AC fittings like the before should do it this way the first few times before you buy the tools because sooner or later you wind up needing to disconnect these kinds of fittings without having the tool around.
tbugher62
04-05-2014 11:38 AM
rhrmusic
05-01-2006 08:27 PM
hillbillyk
04-22-2006 10:36 AM
spidk43
11-28-2005 03:37 PM
bignorthford
12-11-2003 08:17 PM
