Turbo 67 f100 inline 6 300!!
Been turboing my f100 1967 inline 6 300 everything's custom and has been fabbed by me. It's slow but it's happening. So far it's got a Garrett gt38r turbo set up as draw through with 2.5 piping and a Holley 600cfm vacuum secondary carb. Eventually it'll be bagged but it'll retain a rat rod look.
got the car a few months ago and when I have the time or money I do a little something to it.
any idea on how well this turbo will work with this turd?
jeez even your garage is nice!
Check this out. You are a ways into your project, and this one is quite different being a rear mount. However, you might spot a thing or two that will work for you:
https://www.ford-trucks.com/forums/1...6-sleeper.html
Not being a hater because I respect what your trying to do but I have a couple questions. Why did you choose to weld the turbo inlet pipe right to the cast iron exhaust manifold? Also why did you mount your turbo upright? Not saying it’s wrong but I don’t think I’ve ever seen a turbo mounted this way. Good luck with your build.
The cast can penetrate and hold well with a weld if it's preheated a bit. I made it like that for ease the way it is i can access every bolt and take off seperately if i want to and didn't have any adapters and really didn't feel like making any. And the turbo is a flipped intake side up to be a draw through. You can't run a Holley 4 barrel sideways last I checked.
I figured it out J... he's gonna do a draw through..
actually he says it in his original post. I read it, but didn't put the two together either.
Hopefully you put a big enough drain back so its not an issue with turbo mounted that way. Most turbos are t designed for draw through, but if that's a real 38r, the ball bearings might handle it. It typically doesn't have thrust that direction, so I'm unsure if it has ability or not with the ball bearing.
Give it a whirl. I don't really see an issue, other than oil drain. Some turbos are picky.
