239 Guys - Fuel Pump
Old 06-24-2018, 02:23 PM
1954wrecker's Avatar
1954wrecker
1954wrecker is offline
what are the 239 guys running for fuel pumps? I don’t see any replacements or rebuild kits.
Chris
Old 06-24-2018, 03:07 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Do you need vacuum provision for wipers?
I thought all Y blocks can use the same pump, at least if using electric wipers. I use the standard pump that an FE uses in my 292. With the integral fuel filter. Carter 4008 or 3528, I think it's Carter 6984, if filter not needed.
Old 06-24-2018, 03:20 PM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,615 Likes on 1,456 Posts
54 yblocks take a different fuel pump. Hopefully Dennis, Pinto Plumber, will be along shortly. He and some others know more about yblocks than I.
Or post your question on the Yblock forum.
Old 06-24-2018, 03:48 PM
pintoplumber's Avatar
pintoplumber
pintoplumber is offline
Airtex 4070. I carry a spare in case it goes out when I’m racing. Early 239’s had a straight arm on the pump, later Y’s had a bend in the arm. Dennis
Old 06-24-2018, 04:21 PM
1954wrecker
thank you! That looks like the pump that’s currently on my truck going to order it from amazon.
the fuel filter I have just after the pump often looks like it only has a 1/4 inch of gas at the very bottom. Is that normal due to the low PSI or an issue?
thanks,
Chris
Old 06-24-2018, 04:45 PM
pintoplumber
Is your fuel filter between the fuel pump and carburetor ?
Old 06-24-2018, 04:47 PM
1954wrecker
Sorry I mixed that up.
i have one pre pump that is the one that only has a quarter inch of gas in it at times, the second is post pump before the carb. That is a metal canister so I can’t see what’s in there.
Old 06-24-2018, 04:56 PM
pintoplumber
Mine has an air bubble in it, but it’s mostly full. I’ve run out of gas twice when it was very hot about 3/4’s of the way down the track. The pump will probably satisfy your needs. Dennis
schoo
05-16-2013 10:06 AM
turnrjr
06-27-2009 11:54 PM
BaugherGarage
03-13-2008 09:27 PM
Tedybear
12-14-2007 08:42 PM
Quick Reply: 239 Guys - Fuel Pump
