99 7.3 6 speed stalls on downshift coming to stop - Page 3 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 07-10-2018, 11:41 AM
Baatzy
Baatzy is online now
Baatzy is gaining momentum as a positive member of FTE.
I'm still leaning towards something wrong with the IPR mainly. The IPR is operated by a magnetic coil, which would explain the problem cropping up when it gets hot. Magnets get weaker when they get hot.
If it's not the IPR itself, maybe it's the wiring for the IPR, as you said you replaced the IPR. Take a look at the harness, see how it looks?
Otherwise maybe the ICP or ICP wiring is going bad and giving a higher reading than it actually is. They are known to have oil eventually leak by.
Of course I'm just shooting in the dark as we don't have any hard numbers to see what the truck is trying to do when it does this.
I personally don't see how the HPOP could be the problem if you are only having the issue when the engine is slowing down.
Baatzy
  #32
Old 07-10-2018, 12:13 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
Another cautionary tale
Jaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to behold
Here is a link to the torque pro faq, Iím on my fruit powered fone so Iím not sure if signs post or not (supposedly they do not) but read through the first post as there will be a lot of info for you about how to get TP running so we can get some numbers and better diagnose your issue
https://www.ford-trucks.com/forums/1...e-pro-faq.html
  #33
Old 07-11-2018, 03:40 PM
really ole man
really ole man is offline
really ole man is starting off with a positive reputation.
Hi there, Sounds like some of the same things I have happening with my ole Ford. Except, mine seem to be running sweet at cruise, but at a idle or when you slow down to stop. Mine feels as if the throttle linkage was chopped off, Then the engine lopes and act like it has a performance cam, after a few the idle seem to smooth, except then it sounds like it's got a fouled injector or something and the engine is missing. Some one said my throttle pot.....control is bad. Just trying to find some more ideas.
  #34
Old 07-11-2018, 04:56 PM
udsuth78's Avatar
udsuth78
udsuth78 is offline
udsuth78 is starting off with a positive reputation.
I don't know about meier but I've had mine hooked up while it acts up. and the icp just starts dropping and the truck dies. during cranking to restart the icp struggles to climb high enough but the duty cycle is hitting 65%.
here's a trip with the AE recording you can see when it dies, and when I start it back up. if anyone can make since of it I'd love the incite.,
  #35
Old 07-12-2018, 09:59 AM
papadave
papadave is offline
papadave is starting off with a positive reputation.
The ICP only reads pressure at the rail and sends info to computer to adj fuel tabling . if hpop is struggling to get pressure to icp then the ipr or hpop is failing
  #36
Old 07-12-2018, 10:49 AM
udsuth78's Avatar
udsuth78
udsuth78 is offline
well the ipr is new ford unit so just leaves the hpop
  #37
Old 07-12-2018, 05:50 PM
really ole man
I have a new HPOP, IPR,ICP,glow plugs, rebuilt CMP, IDM. . I've read that with the mileage I have on this truck, (325K) there is a good chance that the TPS is worn and not reading right. There were some unit that were produced with 2 little sensor on the throttle arm assembly. I am going to remove it and see how much wear is there.
Since the throttle has a real jerky action when in low gear idling along and when a slight amount of pressure is applied. Act like there is a 1/2 turn slop on the driveline, which there isn't. This is more of a jerking movement that will stop is pressure is applied and you have R's about a grand. I also notice what seem like a slight miss but only at a idle. When taking off and throttle is applied thru the gear I am blowing smoke, lot's never had this problem before always ran clean. Over the past weekend I put about 1800 miles on in 4 days, hauled really good on hiway, crappy in town traffic. Averaged about 18 MPG on trip.
  #38
Old 08-15-2018, 01:14 PM
Sous's Avatar
Sous
Sous is offline
Sous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant future
Any updates on this issue?
  #39
Old 08-15-2018, 03:17 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is online now
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
Last i heard, he bought a newer 5'er, used truck to park trailer somewhere on the Atlantic coast, sold truck and picked up paddleboarding...sounds good to me
  #40
Old 09-17-2018, 03:26 PM
Sous's Avatar
Sous
Sous is offline
Bueller... Bueller... Bueller...
  #41
Old 09-17-2018, 05:44 PM
IDI-Charlie's Avatar
IDI-Charlie
IDI-Charlie is offline
IDI-Charlie has a very good reputation on FTE.IDI-Charlie has a very good reputation on FTE.IDI-Charlie has a very good reputation on FTE.
While my truck wasn't stalling, I no longer seem to have the issue. Occasionally after my new injectors were installed Id'd get the idle drop, but others I wouldn't. Installed a Melling M208 and the issue hasn't raised it's head since...
Cowinkidink? Probably.
nickmobile67
28
04-03-2010 11:39 AM
frank_65
Ranger & B-Series
12-02-2007 07:50 PM
tony b
10-22-2006 04:10 PM
scurbiedog
1978 - 1996 Big Bronco
09-07-2005 02:19 PM
Quick Reply: 99 7.3 6 speed stalls on downshift coming to stop
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
