99 7.3 6 speed stalls on downshift coming to stop
AFAIK it can't be overfilled, it just drains to the crankcase. Sounds like it started right after the oil change; what oil & filter did you use and what was previously used?
Mine stalled on me once but with it rolling, it popped back on. This was exiting the freeway. Never did show its face ripn around town. Just, now i think about it, exiting freeways after being in a high speed issue and tryn to come down in speed quickly..aka, throwing in N or deoress clutch to grab gear. Its when you can here, feel and see RPMs drop lllooooowwww
I have been having the exact same problem with my e99, but my is an auto so no popping the clutch. It has progressed to the point of occasionally leaving me stranded. I have changed the IPR, ICP, 2 CPS, lpop, injectors, and tps. None helped. I scan mine and it's usually an IPR code and when it dies it struggles to build ICP. I hope someone can help with this because I've spent a lot of money and time and not found the problem
Updating my issue.......
So somewhere around the middle of June, I changed my fuel filter thinking maybe that was the issue. It was not. Still had issue. Two days ago the gasket on the new fuel filter blew out ,bathing engine compartment and under carriage in diesel. Not sure why it took a month to fail , but it chose to do so 35 miles from home. I tried to get it to re-seat but we all know how that went. Hell.....sometimes it's difficult to get a new one to properly seat. Anyway called a buddy who brought me a new filter and I was up and running in no time.
So for 30 of the 35 mile drive home was uneventful......no stalls or drops on rpms. I started to think maybe the gasket was slowly leaking before it blew , therefore bleeding off fuel pressure ???? The last 5 miles or so made me scrap that thought! Stalled at 2 red lights, and almost stalled at 2 others. Scratching my head again! The more I deal with this issue, I'm beginning to believe and narrow it down to temperature. It absolutely WILL NOT do it in the a.m., regardless of air temp. On the evening drive home,,however, is a whole different ballgame. Seems as though when the air temp rises into the 80's and 90's , it's guaranteed to happen. In my mind it's got to be something temp related but I'm lost at what it could be. Truck runs absolutely great the rest of the time and this is what really stumps me.....I would think if my low rpm /stalling issue is being caused by a specific part, wouldn't that part failure cause a noticeable decrease in engine performance at all other times?
I would hate for that to be my issue since I am on my second t500 from joey @ terminator. 1st one died just out of his warranty period and he graciously honored the warranty and replaced it free of charge. Current hpop is only a year or so in service so I hope thats not the issue.
Just don't wanna have my truck down as it's livelyhood.
What does the rebuild kit include? I assume hpop removal is necessary for rebuild?
