MN is changing to B20 at the pump. Are there older engines with Bio limits? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 06-22-2018, 03:54 PM
Norski01
Norski01 is offline
Norski01 is starting off with a positive reputation.
Can older engines run on B20? What does Ford state in owner's manual as to limits on Bio? Has Ford come out with statements that would change the allowances in Bio as of June 2018?
Old 06-22-2018, 04:24 PM
Just Strokin
Just Strokin is online now
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
The 6.7 is certified to run up to B20 with no problems per Ford. The 6.0, 6.4 and 7.3 ought not have any problems.
I believe the 6,7 side emblem has B20 on it?
Old 06-22-2018, 05:21 PM
dirthawg's Avatar
dirthawg
dirthawg is online now
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
The 11'-16' do.
Old 06-23-2018, 02:44 PM
senix's Avatar
senix
senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
6.4 was around 10% max as memory serves me right. Check the owners manual on service intervals with Bio, I know for the 6.4 you had to follow a severe duty service interval.
6.7, not so much.
Old 06-23-2018, 06:24 PM
SkiSmuggs
SkiSmuggs is offline
SkiSmuggs has a good reputation on FTE.SkiSmuggs has a good reputation on FTE.
I believe the 6.7L does specify bio-diesel as severe duty. One of a few problems is that you don't know what you will get in the bio as it can be made from several sources and you have no idea how long it has been sitting around. That is important as it is less stable and is prone to change during storage.
Old 06-23-2018, 11:49 PM
camminich's Avatar
camminich
camminich is offline
camminich is starting off with a positive reputation.
It's worth noting that per the manual for the 6.7l if you run B20 you should also be using full synthetic oil. I think many already do, but just a FYI if you do start using B20 on a regular basis.
Old 06-24-2018, 09:15 AM
kper05's Avatar
kper05
kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Attached is from the 2011 diesel supplement, page 86.
Old 07-10-2018, 08:58 AM
W7PSK's Avatar
W7PSK
W7PSK is offline
W7PSK is gaining momentum as a positive member of FTE.
When I was going through California most of the stations run Bio 20. I lost about 4mpg with that crap.
Old 07-10-2018, 09:39 AM
my_crib_too's Avatar
my_crib_too
my_crib_too is online now
my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.
I'm glad that the good people of MN want this fuel in their state. I hope that their high demand for Bio fuel keeps it out of my state.
bruce...
Old 07-10-2018, 11:02 AM
Painted Horse's Avatar
Painted Horse
Painted Horse is offline
Painted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant future
I try to buy a tank of Bio once a month just to help clean everything up on the fuel system.
But stations selling Bio are few and far between
Old 07-10-2018, 11:21 AM
fordmantpw's Avatar
fordmantpw
fordmantpw is online now
fordmantpw is a name known to allfordmantpw is a name known to allfordmantpw is a name known to allfordmantpw is a name known to allfordmantpw is a name known to allfordmantpw is a name known to all
Agreed.
My '08 6.4L would run much quieter on bio, with no noticeable difference in MPG. Then the tank after bio would generally get 1-2 MPG better than normal.
Old 07-10-2018, 12:21 PM
mebe2k's Avatar
mebe2k
mebe2k is offline
mebe2k is gaining momentum as a positive member of FTE.
I've never run b20 in any of my trucks..but I do know the 3116 CAT in my old GMC Topkick does not like B5-B10... noticeable loss in power and MPG..
My 6.7 also doesn't seem as peppy with it either and loses a little mpg..
If they are running B20, how are the older engines like my 6.9 IDI'S going to handle it? Bio sounds like it's going to be the ethanol of the diesel world...trashing the fuel systems of older engines and vehicles..
Old 07-10-2018, 08:40 PM
Curt's05's Avatar
Curt's05
Curt's05 is online now
Wiser by FTE
Curt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud of
Unhappy
My bother in law is a Mn dot master mechanic and the state diesels have a lot of problems with the B20 in the winter! It gels up, clogs the filters and doesn't change back when warmed up, sounds like crap to me...
Some fueling stations are reporting an outage of the B20; https://mn.gov/commerce/industries/fuel/biodiesel/
Old 07-10-2018, 09:26 PM
Iowa Ford's Avatar
Iowa Ford
Iowa Ford is online now
Iowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputation
bruce...
Look close Bruce, I'm sure it's in Wisconsin.
The old 6.9's run fine on it too.
Old 08-19-2018, 09:47 PM
Lifesavr65
Lifesavr65 is offline
Lifesavr65 is starting off with a positive reputation.
On way to Nashville I stumbled on a Loves on I-40 (exit 87) and all they had was B20 at the "normal" pumps. I just got my "new to me" 2011 SD and didnt know what to do. I ended up going to Shell down the road.
Quick Reply: MN is changing to B20 at the pump. Are there older engines with Bio limits?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
