1978 - 1996 Big Bronco
Looking at Clean 1994 Bronco w/180K, 5.7L
Old 07-17-2018, 08:29 AM
02EX73's Avatar
02EX73
02EX73 is offline
Besides the normal items to look/listen/smell/feel for, what are common issues to look for with this truck?
Old 07-17-2018, 02:31 PM
McLeod's Avatar
McLeod
McLeod is offline
Check the tailgate over for rust at bottom edge and also see if the tail gate skin, right behind the tire carrier, has started to work loose/crack/separate.
This is a common problem which if caught in time can be reasonably repaired.
Also, check to see if the B pillar/gutter intersection is badly torn.
This will also leak water into the interior near the base of the seatbelts, which usually causes rust and often starts to corrode the dome light wires near the floor area.
Also, the bronco would have a 5.8/351w in it.
Old 07-17-2018, 07:21 PM
02EX73's Avatar
02EX73
02EX73 is offline
Oops! Yep. Windsor motor. Thx. The truck was clean, bottom door seams were solid, bottom of b pillars were fixed and coated. Tailgate was ok, some rust across the seam. We declined to make an offer. Going back to search for an F150 4x4 w/less mileage.
mzwizanski
20
10-27-2019 12:16 PM
Legend_IMOM
16
04-14-2017 06:15 PM
Mother_Love
WTB - Parts & other
08-05-2012 12:45 PM
Fordfanz
10-06-2004 02:03 PM
ryanguglich
Paint & Bodywork
11-23-2003 07:25 PM
Quick Reply: Looking at Clean 1994 Bronco w/180K, 5.7L
