This is why you need a pre filter/seperator. **video and pic**
I installed the Racor PS120-02 several years ago. Here is my original post. Racor PS120 I have not emptied it since that day. I had a fuel pump issue this weekend and noticed the Racor had a lot of gunk settled in the bottom. This is the very reason I decided on this filter. The housing is clear so you can inspect it whenever you need to. If you go with the Badlwin type filter you never know if/when you need to change it. Also the Baldwin is not re-usable so you are spending money every time you decide to change it. I am very happy with the Racor PS120. Here is a link to the video. I am not able to download it yet as google says it is still processing. I hope this works. If not I will upload it when it is ready. Contaminates filtered out of fuel
I used the Baldwin on my truck and small inline glass bodied strainer on my Excursion. After picking up some trashy fuel in the Excursion and plugging that little inline glass unit several times, I found out about the PS120 and put one on each vehicle! If I had been aware of the PS120 to start with neither the Baldwin nor the glass bodied strainer would have ever been installed to begin with.
Each time I change the oil on the truck I closely inspect the Racor container with a bright light to see if there is anything settled in the bottom. The only time I had to clean it out (so far) is right after doing the H/H mod and had some debris left in the tank.
I also fully support the Racor.
