Rear Axle lock washer...Found! - Ford Truck Enthusiasts Forums
Old 06-21-2018, 06:41 PM
cjbronco
cjbronco is offline
cjbronco is starting off with a positive reputation.
Just want to pass along that I found at Autozone the rear lock washer for my 73 F250 2wd. Had to order from their distribution center but only took 1 day to come in.
Old 06-21-2018, 09:46 PM
somethingclever's Avatar
somethingclever
somethingclever is online now
somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.
Did you install it yet?
Old 06-22-2018, 05:56 AM
cjbronco
cjbronco is offline
Nope not yet. I am waiting for the bearings(Timken) and new axle locknuts. All of the original parts were pretty beat up. I will be taking some pics and will post.
Old 06-22-2018, 09:09 AM
brian1080's Avatar
brian1080
brian1080 is offline
brian1080 has a good reputation on FTE.brian1080 has a good reputation on FTE.
Just went through that myself a while back, good times.
https://www.ford-trucks.com/forums/1...y-morning.html
Old 06-22-2018, 10:31 AM
jakeharp's Avatar
jakeharp
jakeharp is online now
jakeharp is gaining momentum as a positive member of FTE.
Heres a link to my D60 work with some other pics and links that could help you out, having the right size hub nut socket helps tremendously also...
https://www.ford-trucks.com/forums/1...ized-drum.html
https://www.ford-trucks.com/forums/1...e-install.html
https://www.ford-trucks.com/forums/1...-oil-seal.html
Old 06-22-2018, 11:04 AM
TXTrailerdaddy
TXTrailerdaddy is offline
TXTrailerdaddy is starting off with a positive reputation.
I just rebuilt my Dana 60. Took me 3 days off and on. I must have pulled that carrier a 1000 times. The shim pack that came with the new gears was extremely limited. I went to buy more and they gave me shims for between the race and axle tube. Seems I'd run around for parts all morning come home start putting stuff on, and need something new. then I went looking for that same lock nut. Was sold the wrong one at the local gear specialist that was across town. Ultimately I found it at a little gear shop I never knew existed that was 5 miles from my house. I upgraded to disc brakes while I had the axle apart. Just got it all back in and I'm glad to be done with it.
Old 06-24-2018, 12:12 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by cjbronco View Post
Just want to pass along that I found at Autozone the rear lock washer for my 73’ F250 2wd. Had to order from their distribution center but only took 1 day to come in.
There are TWO different sizes of these puppies:
61-1124 .. Rear Wheel Bearing Lock Nut Washer / 2 3/4" O.D. x 1 27/32" I.D. / Obsolete
B6Y-1124-A .. Rear Wheel Bearing Lock Nut Washer / 2 15/16" O.D. x 2 1/32" I.D. / Obsolete
Old 06-24-2018, 07:26 PM
cjbronco
cjbronco is offline
Thanks for the helpful links. I have started to read through much of them. Which part#TIMKEN bearings did you end up using for this project?
Old 06-26-2018, 05:28 PM
jakeharp's Avatar
jakeharp
Thumbs up
If your doing both sides ...
Timken SET38 x 4 (Bearing and Race)
Timken 4250 x 2 (Inner Seal)
Old 06-26-2018, 08:20 PM
cjbronco
cjbronco is offline
After doing some reached I had seen on these forums to use Timken LM104949 (Bearings) inner & outer and then Timken LM104911 (RACES). I am still waiting on the races to arrive, but if i have the incorrect parts that would be GREAT to know ahead of time.
In addition, does anyone know where I can score an inexpensive race driver? The set I have will not work (nothing big enough)
Old 06-27-2018, 07:15 AM
somethingclever
If you're worried about having the correct parts in hand before you start the job, then I think you should get the napa rear lock washer instead of the dorman unit you have.
Old 06-27-2018, 08:40 AM
cjbronco
cjbronco is offline
Sorry I didn't clarify. The concern is on the bearing and race side of things. I ordered the p# I have seen from previous posts on here. However I am seeing from a previous post on this thread about ordering a SET38 instead. Was lust looking for some confirmation since many of you have done this multiple times and this is my first on this rear.
Old 06-27-2018, 09:19 AM
jakeharp's Avatar
jakeharp
#s
SET38 are the same bearings you listed just in a SET with the race so you dont have to buy them separately, its a very common bearing and race........ heres the match numbers from Timkens site..
Set Outer SET38 LM104949-LM104911
Old 06-29-2018, 07:53 PM
bigoldtruck
bigoldtruck is offline
bigoldtruck is starting off with a positive reputation.
I rented a set of bearing race drivers from O'Reilly's. The biggest one of the set was the perfect size.
Old 07-06-2018, 10:22 PM
kydavison's Avatar
kydavison
kydavison is offline
kydavison is starting off with a positive reputation.
Rock Auto sells these in a 10 pack for $5 .I've got them on my next order. I think I paid $8 for two at Napa.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
