AUH connection 2 help
With the ball in its lowest position the trailer is near level and the clearance at the bed rails is approx. 5 inches. I've had 2 occurrences of the trailer contacting the bed rails. Actually, the truck was spared but the frame for my soft bed cover was crushed and the underside of the trailer cap got some nasty cuts. The first time was with the ball in the lowest position.
I had another contact with the ball up in the second pin position. I was turning in the opposite direction that time so I have cuts carved into both sides of the cap now. So I put the ball in the highest position and the trailer bumper hit the ground when climbing a steep grade in the campground. Raising the trailer on it's suspension isn't an option. The specs say the trailer is 13' 5" to the top of the front A/C unit and I'm pretty sure 13' 6" is max by law for RVs. So, I stop at check-in and raise the ball if I feel the campground terrain is going to give me trouble. I'd rather drag the tail of the trailer than crush the bed rails.
I've heard that replacing the axle spacers with shorter ones is one way to lower the truck. I measured mine and they are 3 inches thick. What's the smallest spacer Ford offers. I checked some aftermarket sites and saw 1 inch spacers but they didn't have the stop for the suspension. I'd like to gain at least another inch clearance from the bed rails. Preferably more but that doesn't look likely. With the truck unloaded I measure 53 1/2 inches to the top of the ball. My trailer sits level when the ball is 50 1/2". I haven't measured the squat but 3 inches seems about right. I'll check it next time I hook up.
Ford should add LBSB and LBLB (low bed short bed and low bed long bed) to their list of options. Just a few inches cut from the height of the side rails and tailgate. Sure, it would have downsides for some applications but don't you lose or gain something with any option?
Last edited by UnclKracker; 07-15-2018 at 09:17 AM. Reason: To complete my thoughts at the end
gizzmolink
Fifth Wheel & Gooseneck RV Towing
07-26-2008 07:58 PM
gizzmolink
1999 to 2016 Super Duty
07-12-2008 11:59 PM
