1969 390
#61
My 1969 390 is bored .030 and my crank is turned 10/10. My truck is used to pull my bass boat and boat ramps are all full steep. I will put a posi-tack rear end in my 9" rear end. I will use aluminum edelbrock heads ?with a edelbrock intake ? and holley carb ?. I will need to get a cam also ?. This truck is a long wheel base and my truck is a 3 speed standard. Need a little in put on what might be the best set up for this build. I now have a budget and a roller cam is not in it !!!! I need headers and a dual exhaust more that a roller cam !! Money talks and mine is thin .
#62
#64
Might want to consider swapping in a different trans, 3 spd standard has a pretty fast reverse, not good for backing boats or any other load.
1st gear forward isn't much better for taking off on a steep boat ramp, I see a hot smokey clutch in your future with that trans.
http://www.rsgear.com/products/off-r...-transmissions
#66
I'm getting a bit of conflicting info about what 1st gear ratio is in pickup 3 spd trans, you can put the trans in 1st gear and turn the input shaft to see how many times it must be turned to equal 1 turn of the output shaft. Most 3 spds I messed with had 2.99 1st gear.
Four spd top loader is actually worse with the wide ratio trans having a 2.78 1st gear and the close ratio having a 2.32 1st.
Reverse gear in these trans are normally the same as 1st
The T18-T19 four spd trucks trans has much lower 1st and reverse gears for getting loads moving such as your boat ramp situation.
Another option would be to convert to a automatic trans.
#67
Don't let those two worry you about the 3 speed. It's not as bad as they're telling you. Ford put 3 speeds in millions of trucks. I've driven them, in every kind of situation, never burned out a clutch from the ratio in 1st. If you get wild with it on a steep grade, yea you will. Drive it normally you won't. If you're going to spend a lot of time towing heavy loads on steep grades, yea, invest in a better transmission, but for occasional use, the 3 speed is fine. Re gear the 9 inch while installing Traction-loc first then see how the 3 speed performs.
#68
You never know what's been done to a old truck over the years but I'm assuming his still has the factory gears which with a 3 spd will most likely be 3.50 or 3.70 but could be 3.25's, for all around driving I wouldn't want anything lower than 3.70's.
Not saying a 3 spd trans won't work but for launching and retrieving that bass boat on steep ramps a trans with lower 1st and reverse gears is a 100 times better.
I will say if you keep the 3 spd make sure the e-brake works real good.
#69
That's a requirement no matter what transmission's used. That truck's likely got 3.00's in it now. I had a 70 F100 Camper Special with a 390/3 speed and that's what it had. The six cylinder trucks would have had the 3.50-3.70 ratio rear unless special ordered.
#70
I will put a camper shell on the truck to give that rear end some weight and also I can put my fishing, hunting, and camping gear in the back and keep it dry. I will look at the cost of new gears so when I put the locker in I can put new gears with it. I want a good pulling gear but also a hwy gear too and that may be to much to ask for.
#71
#72
I will run 33" tires if they fit with out having to modify the fenders other wise 31" should fit. I am not into low riders. I like my truck to be a truck. I would like for it to get 15 mile to the gallon gas mileage if that is possible. The engine being .030 over and flat top pistons I might be dreaming.
#73
#74
Thanks for the info baddad 457 I will figure the gears based on 31" tires. I also googled the T-18, T-19 and NV4500 tyranny's. I really like what I read about the NV4500 and I found one but it was on a diesel engine so no go and that one, so still junk yard diving. The NP435 is like the T-18 and T-19 but there is a lot of different bolt on's and square bolt patterns and triangular bolt patterns but the price on these was not bad ($200 to $400 used and $800 to $1200 rebuilt).
