Coming from an OBS 7.3 to a NBS 7.3 question(s)
Hey guys for the past couple years I've owned a 1997 F-350 with the 7.3 and ZF-5 manual 4x2 with 3.55 gears and 286k miles. Just recently I retired the OBS and welcomed a 1999 F-350 with the 7.3 and 4R100 4x4 and 3.73 gears with 220k miles into my household. The 1999 is lifted a pretty decent amount like towers over my OBS but with stock size tires. I've noticed a pretty large power difference right off the bat. My OBS seems to be a speed demon next to the 99. I understand I'm going to have more torque with the OBS 5 speed compared to the automatic, and also with the new truck being lifted on small tires. But is that all? Or am I missing something else. Both trucks are stock besides straight pipes, no chips or anything like that. I've also noticed a big sound difference between the 2, the 99 almost sounds greatly better than my OBS. I understand the 99 is intercooled with a wastegated turbo and also has split shot injectors compared to the OBS Powerstrokes single shot (or am I backwards?). Sorry for the long post i am just curious.
That post is short compared to some. '99 was a split year so you'll want to know if you have an E (early) or L(late). What's your build date? You are right on the injectors and wastegate but I can't tell you why the new one would be slower than the OBS. The best thing to do is get a diagnostics set up up and running so you can ensure that your truck is 100% and go from there. Does the NBS have any gauges? You can get an OBDII adapter and software is cheap or free depending on what platform you're running on your tablet(s).
Look at the front springs and see what shape the u-bolts are that hold the springs down. If they’re square, you have an early 99. If they’re round/semi-round, you have a late 99.
Edit: Since it has a lift kit, whoever put it on might’ve put whatever u-bolts he could find up front so that might not be the best way to tell the difference. The build date should be stamped on the drivers side valve cover though.
I guess it's down to intake manifold diameter, AIH, and spring u-bolts if you can't find the build sheet/date.
I have determined the truck is a L99 as the valve cover is stamped April of '99. And on the E99 intercooler chatter, both E99 7.3s I have driven prior to these were both intercooled, both built in mid or so '98
