1986 F700 engine and driveline locked up
#31
Looking for a piston for the 86 370, got a rod then found the piston is cracked, need P/N D9TE6110B2A, the ones I find at Rockauto show two valve cutouts where the one I took out only has one and it is in a different location. Don't know a good place for old Ford parts, any help appreciated. Patrick
#33
#34
Ok, I remember you saying the engine had been replaced, wasn't sure if it was a used engine or a reman.
With D9TE pistons I say it was used, lots of times aftermarket pistons will look a little different but will work, if your piston only has one valve relief Ford probably made left and right side pistons for that engine, aftermarket makes pistons with 2 valve reliefs so that 1 piston will work on ether side.
#35
Got all the pieces back together, now need the torque and Sequence information and does anyone know if Edlebrock makes an aftermarket intake. Manifold. For the 370? Where can I find the head and other torque values. Thanks again for all the help, Cheers from Alaska, starting to cool off. Patrick
#36
As far as I know the 370-429 truck engines used the same style intake as the 426-460 car engines, but I'm not 100% sure.
Mains 95-105 lbs
Rods 40-45 lbs
Heads 140lbs
Rocker Arms (non adjustable style) 18-22 lbs
Intake manifold 25-30 lbs
Oil pump 25 lbs
Cam bolt 40-45 lbs
Harmonic Damper bolt 70-90 lbs
Flywheel bolts 75-85 lbs
Pressure plate bolts 35 lbs
Front timing cover 12-18 lbs
Here's a photo of the sequence.
Mains 95-105 lbs
Rods 40-45 lbs
Heads 140lbs
Oil pump 25 lbs
Cam bolt 40-45 lbs
#37
Note sure if you honed the cyl walls, but it's always a good thing to do............
Specs from the Ford Factory Shop Manual (Engine) for Medium Heavy F-, B-, C-600 Thru 8000 Series:
6.1L (370 CID) V-8 and 7.0L (429 CID) V-8 Engines
Cylinder Head Bolts:
Tighten in Steps: First 70-80 Ft Lbs
Second 100-110 Ft Lbs
Final 130-140 Ft Lbs
Also, not sure how "dry" your engine has gotten, but I ALWAYS use compressed air to pre-lube ........................many just rely on the starter with wires pulled, but that may contribute to an "infant mortality" on those new rings....................bottom line: assembly lubes are "ok", but can fail......seen that happen on big bucks NASCAR engines.................
#38
Just an update from the North, engine all back together, ready to put it. In tomorrow, hope it works, freight charges to Alaska will keep you up at night. No snow yet beautiful weather, just wish I had gotten here about two weeks earlier, the Salmon are to old to smoke so have quit fishing. Will update engine/dumptruck after tomorrow, thanks all for the help, Patrick
BIG ATS
03-15-2012 10:57 AM
