302 Roller Questions.
Recently tore down a 79 block out of a project truck, further investigation and helps from the fine folks on this forum let me know the block was pretty much dead (060 over, bad cylinder scoring, yada yada yada).
started looking for a new block and Boom! Somebody shutting down a machine shop about an hour away was selling a rebuilt 85’ roller motor! Came wrapped in plastic, crank and cam installed with all new bearings, pistons, etc.
Now! All the info I’ve got is for a older block. Got a few questions.
the original motor had a nice aftermarket cam in it that remained in good shape, can I run the older cam and pushrods with the new block and no problems?
if I went with the roller cam and lifters, would I need different push rods to work with my heads of the 79’ block? Heads are same ol’ boat anchors, but they’ve been worked over, look great, and I’m not building a race car.
Any of the accessory’s change? Water pump? Oil pump? Timing chain cover? Fly wheel (changing to 50oz?)
my research on on the block says it’s a HO, does that play into anything?
Sorry for the ramble, but almost like starting the build over, seeing what parts can be salvaged, and frantically trying to find receipts!
The 85 roller block has basically the same iron content as the 80-84 block. They added 2 lbs for the taller lifter bores. Has the same thin decks that caused problems as the earlier ones. Not sure why you'd want to use a flat tappet cam in a roller block here. Roller pushrods are shorter by about a half inch. All the bolt holes are the same for all 302 blocks, so you can use any accessory setup, you cannot generally as a rule mix parts from one setup to another, you'll run into all sorts of fitment issues doing that. And there's no such thing as an HO block. Ford used the same blocks in all applications with different internals
I guess the only reason I was thinking about using the flat Tap cam was the fact that I have new lifters for it and I know that cam, push rod, lifter, Head combo works.
I gotcha it’s not the greatest block. But finding something that’s freshly bored 030 over, re decked, new pistons, new bearings, new cam, and balanced, sitting in an engine bag still sealed up for 225 bucks is hard to argue with. And, it’s my first time screwing around with a roller block, so If mess it up, no harm no foul! Lol! You’ve told me before to find something later than 92 I believe, that’s the plan later down the road once I got my sea legs.
Im assuming the flex plate And harmonic balancer will have to be 50oz versions because of the crankshaft on that year?
Bmoodie10
12-24-2018 05:28 PM
f-trucker88
01-02-2012 10:55 AM
roger dowty
01-04-2007 08:20 AM
