LOL! *ALMOST* as entertaining as the dude over on the 6.7 PSD forum that made his own homemade DEF!!!! And wonders if his CEL light will turn off on its own!!!!
Diesel pumps don't just switch to gasoline when they run out of diesel...
Sure they do.... low pressure off-shore air is well known to bring in certain strains of steel-osmotic algae which when combined with ESE rainwater vapour turn 2-D UST contents directly to gasoline via cathodic affects from ionized air... yeah yeah... that's it...
Look, we all make mistakes and it is much easier under serious pressure. S*** happens.
I filled all the the with gas. Never started it. Drained all I could. Put 2gallon of Howes in it .Filled with diesel. Never looked back. In a 2015 F350.
Employee put def in another 15. 11000.00 to fix at Wide Ford in Bismarck ND.
Wonder if they changed the nozzle? Can't pump unleaded into a car without the correct nozzle.
FWIW: Know a guy who new a guy that added one gallon of gasoline with every fillup of his 6.0. The guy was a petro-chem engineer and the truck ran 500k+.
