Off-Centered Axle w/ No Lift - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 06-18-2018, 12:27 PM
MadeInDade's Avatar
MadeInDade
MadeInDade is offline
MadeInDade is starting off with a positive reputation.
I've had my Super Duty for a couple weeks now and I just noticed that the front axle is off-centered. I have done no modifications to the truck whatsoever. I know this is a common consequence of leveling or lifting a truck, but should it be off-centered from the factory? All of the adjustable trackbars that I have seen on the market are for lifted trucks and don't work at stock height.
Passenger Side Tucked
Driver Side Stick-Out
Old 06-18-2018, 12:33 PM
17350kr
17350kr is offline
17350kr is starting off with a positive reputation.
Do you have snow plow prep or heavy service front suspension? I know they set a little higher. I wonder if they use all the same track bar for all the trucks 250-550 and the difference in night causes the shift. Just a guess.
Old 06-18-2018, 12:43 PM
MadeInDade's Avatar
MadeInDade
I do have the Snow Plow Prep Package.
Old 06-18-2018, 05:50 PM
Flyct
Flyct is offline
Flyct is starting off with a positive reputation.
And you need that in Miami Why?
Old 06-18-2018, 05:54 PM
fmuguira
fmuguira is offline
fmuguira is starting off with a positive reputation.
I too have the SP package on my totally stock F350 KR and my axle sticks out the driver side exactly like yours!
Old 06-18-2018, 08:34 PM
MadeInDade's Avatar
MadeInDade
Haha. Good question. I bought the truck out of state and it was already equipped with the package.
Old 06-18-2018, 10:33 PM
toymaster's Avatar
toymaster
toymaster is online now
toymaster is starting off with a positive reputation.
Makes sense as the SP only adds higher rated (thereby taller) springs and nothing else. The truck is pushed up away from the axle, the track bar angle is increase, and pulls the axle to one side.
Old 06-18-2018, 10:39 PM
Section179
Section179 is offline
Section179 is starting off with a positive reputation.
Any theories on the easiest fix for this? Adjustable track bar? Is there one that adjusts down that much (Iíve read the Carli will push you out the other side before 3Ē Iíd lift)?
Old 06-18-2018, 11:12 PM
LiquidSteam's Avatar
LiquidSteam
LiquidSteam is online now
LiquidSteam is gaining momentum as a positive member of FTE.
Maybe try the BDS 2 inch track bar bracket. Or....swap your 6000lb springs for my 5600lb springs....
Old 06-19-2018, 06:55 AM
brandon4
brandon4 is online now
brandon4 is gaining momentum as a positive member of FTE.brandon4 is gaining momentum as a positive member of FTE.
I have had the snow plow pkg for 13 trucks. I do not believe it raises the front. Except on gas trucks.
My .02
Old 06-19-2018, 08:12 AM
homerj
homerj is offline
homerj is starting off with a positive reputation.
Donít look at your back ones... odds are the passenger side sticks out more to. I know mine does.
Old 06-19-2018, 08:31 AM
Bigblock17
Bigblock17 is offline
Bigblock17 is starting off with a positive reputation.
Does the back of the cab and bed lineup perfect? Or is one side out more than the other? On my truck there off.
Old 06-19-2018, 10:35 AM
BowtieConvert
BowtieConvert is offline
BowtieConvert is gaining momentum as a positive member of FTE.
I have basically the same truck as MID but mine appears to be pretty symmetrical. Kind of looks like the photos were taken at different angles maybe.
Old 06-19-2018, 11:26 AM
willynilly
willynilly is offline
willynilly is gaining momentum as a positive member of FTE.
several easy ways to see if the axle is off center
Old 06-19-2018, 11:46 AM
MadeInDade's Avatar
MadeInDade
Im not an expert photographer, but believe me there is a difference between the two. I have an appointment with Ford service on Thursday so Iíll see what they say.
Quick Reply: Off-Centered Axle w/ No Lift
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
