Using Tow Haul while towing 5th wheel
I am about to take a long trip into the Rocky Mountain National Park/Estes Park, and I want to make sure as I tow my 10,000 pd 5th wheel with my 2014 F250 6.7 that while in Tow Haul that it is ok that the transmission on steep hills downshifts into 2nd? There are times in the past when I have been towing my trailer and I am heading downhill the transmission goes into 2nd gear and makes me a bit nervous, not sure if I should go into manual and down/upshift manually?
Would love to hear your thoughts..
I like to use the cruise control also. When I'm approaching a steep downhill section, there is usually a reduced speed limit sign for the truckers.....say 45 mph for the downhill. As I get close to the top, I'll reduce the speed, via the C.C. to 45 and let it re-engage at that speed. Between the cruise, the tow haul mode, and the engine braking, I usually never have to touch the brake pedal. It's an awesome system, let it do what it's supposed to do.
Received 6,673 Likes
on
