Won't Start in Park, Will in Neutral
There are a couple of screws that hold the gear selector lever in place. I'd check that first. Crawl up under the dash and see if you can see where the lever connects to the column. You may have to remove the plastic steering column cover to get to them.
If I remember correctly, you'll need a torx screw driver to tighten things back up.
I tightened up the screws, as above, and adjusted the cable, as per the Chilton manual. So far, so good. The DTRS is next if it acts up again. I really appreciate the input. I had also had a problem with the cruise control, and searched here on FTE to find the fix (loose brake switch on pedal). Thanks!
you should start a new thread and tell us what happens when it doesn’t start this one is almost 10 years old, does it crank and not stat does nothing all happened no cranking do you hear he fuel pump run for a few seconds when you turn the key on do you have electrical power. We need to know more that it won’t start.
ndanielle1968
08-02-2015 08:22 AM
MonroeHandyMan
12-20-2014 04:52 AM
bthr22
1999 to 2016 Super Duty
22
08-25-2013 05:23 PM
LUMBERMAN
02-22-2010 11:31 PM
