Frekin DipStick Tube!!!!
Jpegg, Just read your post quickly at my lunchtime.Just make sure you understand the difference between actual "oil pressure": (40lbs,60lbs.,80lbs., whatever) that is governed by the oil pump sending oil ,by pressure,thru' your engine tolerances.... like camshaft to camshaft bearings,crankshaft to main bearings etc,etc. All these pressures are governed by the oil pump and these many tolerances. As opposed to crankcase/oil pan pressure which is your internal moving parts, like pistons etc.,creating a pulling/pushing of AIR in the motor. This is where folks are heading with the answer to your problem. There has to be an outlet for this air moving in and out of the oil pan & engine via PCV valves etc. A very oversimplification of the engine but just wanted to make sure you are on the same page as the doctors here. Good luck,you'll get it!
I have 140lbs of compression on avaerage, I do have pvc valve hooked and does not smoke. But let's assume there is no excessive crankcase pressure, if the dipstick tube fitting was to small of size for the hole at pan wouldn't oil still blow out hole?
yes but dipstick tube end was to small for hole, the sent wrong tube but also said they don't have correct sized one. They say the mounting fitting at pan is wrong so I either take pan off and return it for correct one or install a new tube
Yes, but there's no provision on a original engine oil dipstick tube to install an o-ring.
Since the pan is a replacement, if it came w/a tube, it may not match the original.
C8SZ-6754-A .. 429/460 Engine Oil Dipstick Tube - 6 19/32" long / Obsolete
1968/73 Ford/Merc Passenger Car 429; 1968/78 Lincoln/Continental Mark III/IV/V 460; 1972/76 Thunderbird 460; 1973/78 Ford/Merc Passenger Car 460; 1973/79 F100/350 460.
tstorm
03-20-2011 11:07 AM
LARIAT 85
04-30-2010 11:37 AM
