56 f100 wiring harness - Ford Truck Enthusiasts Forums
Old 06-16-2018, 09:56 AM
chickenrancher's Avatar
chickenrancher
chickenrancher is offline
chickenrancher is starting off with a positive reputation.
Hello all, I'm fairly new here and I need some feedback from the board , I will soon be purchasing a stock reproduction wiring harness for my 56 and I want as close to original with molded ends , So far the offerings are Obsolete in Oklahoma made by Bauer Electronics , Mac's has one and states it is Ecklers brand {which I doubt they make themselves} and Dennis Carpenter which is very pricey . I have converted to a GM 12si alt 3 wire and am running the idiot light with the alt field wire and will be changing to Mid Fifty's stock looking volt meter ,Do I terminate the alt side idiot light wire and use the Batt/ign side wire to run the volt meter? Who do you think sell s the best wirng harness?
Old 06-16-2018, 09:37 PM
abe's Avatar
abe
abe is offline
abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.
Check MidFifty. I bought a stock looking harness for my 54 from them.
Old 06-17-2018, 11:36 AM
chickenrancher
Mid Fifty does'nt offer molded ends like original ,my harness is pretty toasty and hacked on .I figure I better change it before Murphy comes knocking, Fewer folks are doing stock resto's I guess .Was hoping to get more opinions from others who did the same.
Old 06-17-2018, 02:43 PM
hulleywoodworking
hulleywoodworking is offline
hulleywoodworking has a good reputation on FTE.hulleywoodworking has a good reputation on FTE.
I bought the complete correct harness set for my 51 from Tryee Harris. Had all of the correct connectors. Nice guy to work with!!
Old 06-17-2018, 04:57 PM
abe's Avatar
abe
abe is offline
I am not sure now by what you mean by molded ends, but the harness I bought from MidFifty was exactly like the original with original type ends except that there was rubber insulation under the cloth. That was back in 1999.
Old 06-17-2018, 06:34 PM
chickenrancher
The 56 did not use cloth covered wiring ,may have been the 1st year for that and the female plugs are molded rubber over the terminals bonded to the wire, the males are the round bullet pins. Mid Fifty's harness appears to have crimped terminals .The molded end harnesses cost considerably more but they are correct for 56
Old 06-17-2018, 10:02 PM
truckeemtnfords
truckeemtnfords is offline
truckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud of
Sacramento Vintage offers stock type harnesses, give them a look.
Old 06-17-2018, 10:08 PM
abe's Avatar
abe
abe is offline
I never knew that about 56 wiring harness.
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is offline
bigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant future
I guess Im not seeing the reason for you wanting the "close to original with molded ends" and then you are going to run a GM alternator? No sense in worrying about original looking ends since it already isn't original
Old 06-17-2018, 11:57 PM
chickenrancher
Not so much about the looks as the quality and durability .
Midnite1987
04-28-2018 10:55 PM
shanes66charger
Ford Truck Parts for Sale
04-04-2016 02:20 PM
Johnlwlr
1999 to 2016 Super Duty
05-25-2011 11:04 PM
LaredoF350
03-10-2008 09:18 AM
birdchaser1
02-22-2002 07:14 PM
Quick Reply: 56 f100 wiring harness
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
