New Ford 7.3 l V8 gas with pushrods - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 06-16-2018, 04:08 AM
CGiron
CGiron is offline
CGiron is gaining momentum as a positive member of FTE.
Thumbs up New Ford 7.3 l V8 gas with pushrods
New Engine with CGI in the block
Will it come at NAIAS ? Around 450 hp? It will be smaller in height than the current 7.3 as itīs a pushrod and smaller overall size as itīs CGI-block can be made with thinner walls. Opinions?
The tuners will love it.
CGI is used overall the NASCAR racing since long and Ford har currently four engines with block in CGI, The 6.7 l V8 PowerStroke, the 3 l V6 new diesel, the 2,7 l V6 EcoBoost and a 4.4 l V8 diesel just used in Land Rovers
Old 06-16-2018, 05:42 AM
tseekins's Avatar
tseekins
tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Here's another link with a bit less detail: Is Ford Going the Pushrod Route With Its New V8? - The Truth About Cars
Old 06-17-2018, 01:51 AM
Scorpion67
Scorpion67 is offline
Scorpion67 is gaining momentum as a positive member of FTE.
CGI would make sense, but Iím not betting on Ford doing something that makes sense. I will bet on the power and torque figures though. On Super Duty (not cab chassis), Iím going with 470/560.
Old 06-17-2018, 11:04 AM
Tom's Avatar
Tom
Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Very interesting, this will be a good one to follow.
Originally Posted by Scorpion67
CGI would make sense, but I’m not betting on Ford doing something that makes sense.
What makes you say that? CGI has its benefits, but it's also more expensive. It seems to shine in applications making a high specific output under boost (think 2.7L EB and 6.7L PSD), but they've been using grey iron blocks for decades without longevity issues. What would be improved in an N/A engine to justify the cost of CGI? If it makes that much sense, why aren't other manufacturers using this for their truck engines?
Old 06-17-2018, 01:25 PM
oklarado
oklarado is online now
oklarado is gaining momentum as a positive member of FTE.
Give me 470/560, and 15 hwy mpg and I will be done with diesel for good!
Old 06-17-2018, 01:42 PM
troverman's Avatar
troverman
troverman is online now
troverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud of
It would be interesting to see Ford return to an OHV engine (the 6.7L diesel already is) but it seems a very opposite design to current Ford strategy. Itís no secret that OHV engines tend to have more torque, and perhaps Ford sees the success GM is having with simple,
powerful and efficient OHV engines
Old 06-17-2018, 03:41 PM
Tom's Avatar
Tom
Tom is online now
Wait...what?
What exactly does camshaft location have to do with torque? The Ford DOHC 5.0L V8 makes more torque than the GM 5.3L does...did nobody tell the 5.3L design team they did it wrong?
I'd completely agree with this. There's a lot to be said for the simplicity of OHV engines, and they seem to hold up quite well over the years with minor revisions.
[/QUOTE]
Old 06-17-2018, 03:52 PM
Dentside
Dentside is offline
Dentside is starting off with a positive reputation.
CGI in this application only makes sense from a weight savings perspective, and I'm not an engineer so I don't know the savings vs. the added expense.
The cynic in me still believes Ford won't offer a gas engine with more HP than the diesel. No way they're going to undercut a $9000 markup.
This is most likely going in chassis cabs and motorhome duty only.
Old 06-17-2018, 05:26 PM
troverman's Avatar
troverman
Originally Posted by Tom View Post
Wait...what?
Thatís one example. The GM 6.2 makes more power and torque than the Ford 6.2. OHC engines tend to rev higher and make their power up higher. Notice I say ďtendĒ because itís not always the case...but historically OHC engines produce less torque
Old 06-17-2018, 06:10 PM
640 CI Aluminum FORD
640 CI Aluminum FORD is offline
640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.
This is almost enough to make me consider diving back into car payments.
Old 06-17-2018, 07:21 PM
Tom's Avatar
Tom
Tom is online now
I dunno...the gas engines always had more power than the diesel option in the past. That changed in 2011, but PSDs were commanding an $8K markup for years prior to that.
The GM 6.2L is a different animal, though. It's got significantly higher compression than the 6.0L offered in their HD models, and has significantly more torque. I imagine the 6.0L mill they put into the GM HD models is nerfed down on power for durability reasons just like the Ford 6.2L is. Half-ton engines, in comparison, almost always have higher specific output.
BTW, the Ram HD's pushrod 6.4L Hemi makes 1 ft-lb less of peak torque than the Ford 6.2L. I suppose those engineers did it wrong as well.
Old 06-17-2018, 08:07 PM
troverman's Avatar
troverman
I knew youíd mention the 6.4 Hemi, Tom. But keep in mind the power output of this engine in the 392 Charger. And frankly, the 6.2L Ford still put out less than the 6.2L GM in the Raptor and F150.
Old 06-21-2018, 02:32 AM
CGiron
CGiron is offline
I think it makes sence in overall weight and size as the cylinderwalls in a CGI-block can be thinner with the same strenght. A smaller engine may fit in smaller enginebays. By the way, Cummins will show their upgraded 6.7 l inline 6 diesel in a few months. With CGI in the block.
https://5thgenrams.com/community/thr...cgi-block.482/
Old 06-22-2018, 02:28 AM
Scorpion67
when it comes out in 2020, the diesel will also have nore hp than it does currently. Higher purchase price and markup are not even close to being the same thing.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
