problems with diesels that sit long time
I currently have a 03 F150 4.6L. I am doing research on new f250. I don't drive my truck as my daily driver. It is my go out in the forest and play/tow sxs truck. So, my truck sits weeks before I drive it. My question do the diesel engine have problems sitting undriven for long periods? Water condensation in fuel tank or other problems?
truck & sxs
truck & sxs
Im not a sure a diesel is any worse than a gasser. Modern day gasoline has a short shelf life due to ethanol ....about the same shelf life as DEF.
Do you feel like you want a diesel? With limited driving, I think it makes a lot of financial sense to go with the 6.2 and 4.30 gears.
Diesel is far more stable than any ethanol blended gasoline. But you can add fuel stabilizer for either.
Condensation is not much of a concern, my tractor sits for weeks at a time and I never have any water at all in the fuel separator.
All modern diesel vehicles will have a water separator in the fuel line. You can also keep the fuel tank full to minimize the possibility of condensation if you wish.
DEF might me a concern if you were putting less than 2-3k miles a year on the vehicle, but if you drive > 5-7k miles a year you would use enough to keep it fresh.
Received 6,656 Likes
on
Not a big deal....diesel trucks sit on lots, weeks or longer at a time.. Mine sits in the garage from late fall to early spring, gets started every few of weeks and driven if the weather permits. I do keep a trickle charger on the battery. I only drive (pull the RV) about 7500 mi per yr.
I've had my f150 for 14 years not one mechanical problem with it only has 80K on it. Just underpowered towing up the mountains. Someday I would love to have a toy hauler.
I am leaning toward the 6.2 gasser. Just trying to get some info on diesels. I tow in the mountains 4000-10000 feet all the time. That's where the best trails are. So the extra pulling power would be nice, but the extra $$ isn't. I would love a 6.2 with 4.30, but those are like finding a four leaf clover. Has to be special ordered. I was hoping to find a gently used 1-2 year old truck.
on
My 15 was 4 years old in May and has 38,000 miles. I plow with it and tow my camper and that's pretty much it. It stays in the garage and I'll take it for a drive every couple of weeks. At 9,000 miles a year, I have had zero issues. It is no different then a gassed. Only thing you may see is flat spots on the tires.
I have an Enterprise rental... I think the basic XLT are all, 6.2L with 3.73 rear... But really clean with low miles. 10k to 15k... 603a pkg with carpet delete and a drop-in bedliner.... SonetimSo they dump a bunch to auction and end up on dealer lots... They also sell them on their website... There are a few diesel and dually there too
22rimfire
6.7L Power Stroke Diesel
16
04-22-2015 09:49 AM
