2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Air Suspension compressor not turning after shocks replacement
Old 06-15-2018, 07:02 PM
luxcar's Avatar
luxcar
luxcar is offline
Rear shocks were changed by independent shop on my 2012 Navigator L. Suspension is not raising. Mechanic towed it to Quick lane auto for calibration but compressor is not kicking in. No issues before the shocks change. Any ideas? Mechanic did turn the air suspension off before changing shocks.
Old 06-15-2018, 07:30 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Well, did he turn them back on afterwards?
Old 06-15-2018, 07:35 PM
luxcar's Avatar
luxcar
luxcar is offline
Yes he did. Can low battery cause it?
Old 06-15-2018, 08:38 PM
pdqford's Avatar
pdqford
pdqford is offline
Maybe the new shocks have raised it up so it’s not calling for compressor air?
Old 06-15-2018, 08:48 PM
luxcar's Avatar
luxcar
luxcar is offline
Shocks are OEM motorcraft shocks. The rear is low and air bags are deflated.
Old 06-16-2018, 08:53 AM
luxcar's Avatar
luxcar
luxcar is offline
Quick Lane diagnosed bad compressor. I have ordered Arnott compressor. I find it strange that there was no issue before and compressor failed right after shock replacement.
Old 06-16-2018, 11:04 PM
luxcar's Avatar
luxcar
luxcar is offline
Update:
Indy used Matco Tools scanner and was able to turn the compressor on and solenoids on and off. He saw a bunch of codes related to low battery and charging system. Alternator and battery were replaced a week ago. He is saying that alternator is under charging. I am taking it to dealer on monday for diagnostic. For now I have disabled the air suspension.
Old 06-17-2018, 11:37 AM
alloro's Avatar
alloro
alloro is offline
Received 4,187 Likes on 2,425 Posts
The compressor is disabled during low voltage conditions. I guess they figure it's better to have available power for the ignition system instead of the air suspension.
Old 06-17-2018, 10:49 PM
luxcar's Avatar
luxcar
luxcar is offline
Update:
Have the alternator and battery tested at Autozone and both tested ok. I will still take it to dealer to diagnose charging system.
Indy put air in both rear springs before disconnecting solenoids. Passenger side rear has dropped half an inch in 24 hours. Can I replace just one air spring or do they have to be in pairs. I am looking to replace with Arnott air spring.
Old 06-22-2018, 01:21 PM
luxcar's Avatar
luxcar
luxcar is offline
Lincoln dealer diagnosed leak on rear driver side. They put new Arnott Air spring but driver side rear is still leaking. They suspect bad strut mount and ordered a new strut mount.
What a nightmare. So for replaced shocks, replaced rear air spring, ordered new air compressor and strut mount.
Old 06-29-2018, 12:07 PM
luxcar's Avatar
luxcar
luxcar is offline
Update:
Truck is fixed. The indy shop did not put seals for air spring. Compressor is ok. It was not raising due to leak. Lincoln installed Arnott air spring (comes with seals) and strut mount.
Lincoln diagnosed bad alternator. Alternator replaced under warranty by shop that installed it.
ARK Ranger
1997-2006 Expedition & Navigator
07-18-2011 08:22 PM
matts2000expo
10-24-2007 04:12 AM
Omahastro1
02-15-2007 05:31 PM
ssmokinss
01-18-2007 03:42 PM
martypeep
1999 to 2016 Super Duty
01-23-2005 10:59 PM
Quick Reply: Air Suspension compressor not turning after shocks replacement
