Air Suspension compressor not turning after shocks replacement
Rear shocks were changed by independent shop on my 2012 Navigator L. Suspension is not raising. Mechanic towed it to Quick lane auto for calibration but compressor is not kicking in. No issues before the shocks change. Any ideas? Mechanic did turn the air suspension off before changing shocks.
Indy used Matco Tools scanner and was able to turn the compressor on and solenoids on and off. He saw a bunch of codes related to low battery and charging system. Alternator and battery were replaced a week ago. He is saying that alternator is under charging. I am taking it to dealer on monday for diagnostic. For now I have disabled the air suspension.
Update:
Have the alternator and battery tested at Autozone and both tested ok. I will still take it to dealer to diagnose charging system.
Indy put air in both rear springs before disconnecting solenoids. Passenger side rear has dropped half an inch in 24 hours. Can I replace just one air spring or do they have to be in pairs. I am looking to replace with Arnott air spring.
Lincoln dealer diagnosed leak on rear driver side. They put new Arnott Air spring but driver side rear is still leaking. They suspect bad strut mount and ordered a new strut mount.
What a nightmare. So for replaced shocks, replaced rear air spring, ordered new air compressor and strut mount.
Update:
Truck is fixed. The indy shop did not put seals for air spring. Compressor is ok. It was not raising due to leak. Lincoln installed Arnott air spring (comes with seals) and strut mount.
Lincoln diagnosed bad alternator. Alternator replaced under warranty by shop that installed it.
matts2000expo
1997-2006 Expedition & Navigator
10-24-2007 04:12 AM
