2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
Purchasing forward fleet vehicle
Old Jun 14, 2018 | 08:39 PM
N86cm's Avatar
N86cm
Just as the title says. I’m looking at purchasing a ford fleet vehicle. It was a registered in Virginia Beach. It’s a 2017 Expedition with 33, 000 miles on it. Then taken to an auction where a local dealer purchased it. Is there anything that I need to be aware of before purchasing a Ford Fleet Vehicle? Are they usually serviced properly?
Thanks,
cm
Old Jun 15, 2018 | 02:25 PM
EXPE15's Avatar
EXPE15
If it was a Ford Corporate fleet then probably service was pretty good. If it was a Ford Fleet then it was probably used for street testing, could have been one of the demos that they use for the "Ride and Drive" events at car shows around the country. I would suspect that if it was driven by auto show customers those drives are pretty tightly controlled. Wouldn't hurt to ask but you could be good. Registered in Virginia Beach is a little weird though. That could be a local fleet use, Rental, Government fleet etc... Even as a rental probably did normal scheduled maintenance OLF, etc. Hopefully you can check it out local before purchase. Good Luck keep us posted.
CARFAX Would be your first step. That will give some indication of the previous user.
Old Jun 15, 2018 | 09:12 PM
85e150's Avatar
85e150
Buy an ESP warranty out as far as you can see.
Driven with the utmost care and professionalism. Or beaten like a rented mule.
Does it still have the OEM tires?
How do the brakes look? Will they let you check the lining thickness? Fronts should be over 50%, rears over 75% at that mileage.
Old Jun 18, 2018 | 12:34 PM
YoGeorge's Avatar
YoGeorge
If its an XLT, it was most likely a rental. If it's a Limited or above, it might have been a corporate fleet lease, but these are not hard and fast rules. 33k miles is too many miles for an auto show demo. Rentals are often used for family road trips and can build up more miles. A CarFax report will disclose if the vehicle was a rental.
In general, people don't abuse rentals although some (like the young version of me) do tend to thrash them although driving with your foot on the floor is not gonna hurt a vehicle that much, really.. As 85e suggests, if you can buy an extended warranty with some of the money you're saving by buying a fleet vehicle, it may serve you very well regardless of how the truck was treated. And do check things like brakes and tires for wear that syncs with mileage. If the front brake pads are far gone, it may have been a hard-driven city rental. If they are very slightly worn, it may have been used for road-trip type rental service.
George
Old Jun 18, 2018 | 01:01 PM
EXPE15's Avatar
EXPE15
That makes sense on the rental theory. If I get a rental it is usually for a major road trip. The most likely scenario is winter and even though I am in Texas request 4WD. I usually rent for two reasons 4WD and save my miles. Texas is fine for no snow and destination area might be fine but in the winter any weather could be encountered en route so like to be prepared.
All valid points on CARFAX and extended warranty plans if available. Sounds like a decent deal but do your homework as they say.
walleyealx
2015 - 2020 F150
Apr 10, 2019 07:19 AM
cjusr
2009 - 2014 F150
13
Nov 8, 2018 10:20 AM
Texascyclist
Jan 4, 2016 11:08 AM
TOUGHLover
General Automotive Discussion
Jul 23, 2009 10:04 AM
saipan
May 28, 2005 05:12 PM
