Squishy brakes
Squishy brakes
everyone helped me with my last problem so I’m hoping someone can point me in the right direction with my squishy brakes. We did a disk convertion in the front with new lines and good calipers. Rear drums are new and adjusted. Probably went through a gallon of brake fluid bleeding it and still squishy. Any ideas?
What differential/proportioning valve did you use? The stock Ford ones have a bleeder valve on them that must be pulled out or pushed in, in order to get fluid to flow to the front brakes. You will still get fluid but you may never get all the air out unless that metering valve is held open.
Brake bleeding
Check out the rod length on the power booster. It might not be long enough to go all the way into the master cylinder. Especially if your power booster is aftermarket. That was my issue after doing disc/drum total replacement from drum/drum. I did all new to include lines, calipers rotors, etc.
Holehawgg
01-06-2015 01:17 PM
shameless
10-01-2011 03:25 PM
Green Streak
04-17-2010 11:43 AM
Dan-79F350
05-17-2000 03:19 PM
