05 F-150, 5.4 Lariat Bent Rod #1 cylinder. - Page 9 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Reload this Page >
  #121
Old 08-06-2018, 08:49 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
I wouldn't have used that headgasket. The blue headgaskets are a different thickness than the original and need to be replaced in pairs or one bank of the engine will have a different compression ratio and a balance issue.
  #122
Old 08-08-2018, 04:40 PM
gamboni's Avatar
gamboni
gamboni is offline
gamboni is starting off with a positive reputation.
Thank you ford390gashog for the advice but it's too late now. I hope it;s not an issue.
@ 70f100longbed, got the OH cams on and was going to install the phasers but I noticed when I tightened down ( Snug not torque yet) the cam caps the cams rotated????? Check out the picture. Is this OK?
  #123
Old 08-08-2018, 05:34 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.
That will be fine let them find a neutral spot. They aren't out of time enough to worry about the valves. They moved because a cam lobe was making a valve open and the spring pressure pushed back. You did remember to put some oil on the bearing surfaces right?
  #124
Old 08-08-2018, 05:38 PM
gamboni's Avatar
gamboni
gamboni is offline
I soaked the lifters and rocker arms in a bucket of oil before I installed them. That was all I did. Should I squirt some more on the lobs?
  #125
Old 08-08-2018, 05:58 PM
70f100longbed
You should pull the cam caps and oil the bearing surfaces in the head and cam. Definitely don't want that to be dry when you start it. It doesn't take long for the steel cam to damage the aluminum head.
  #126
Old 08-08-2018, 09:03 PM
gamboni's Avatar
gamboni
gamboni is offline
OK, will do tomorrow. Thank you for the valuable advice.
  #127
Old 08-10-2018, 12:23 PM
gamboni's Avatar
gamboni
gamboni is offline
OK, done with removing cams and installing new phasers. Something does not look right. Are the phasers supposed to be this far off? The driver side goes on a lot furthers then the passenger side. Do I need to tap it with a rubber mallet, I can't get it on any further. Check out the picture below?
Thank you for your help.
  #128
Old 08-10-2018, 12:25 PM
gamboni's Avatar
gamboni
gamboni is offline
@70f100longbed, if all is OK, Are we ready to install timing belts, tensioners and guides. Not really sure what is best to do next ?
  #129
Old 08-10-2018, 12:46 PM
70f100longbed
That's normal. The right side sticks out a little farther than the left. Start by installing the fixed guides. Then the left chain, arm, and tensioner. The left arm has a small bump by the pivot and the right one does not. Once the left side is together and verified in time then install the right side chain, arm, and tensioner. To time it stretch the chain out like ========== and one end will look like l and the other end like =. Mark all 3 links with white paint or something that's easy to see. The l link goes on the crank gear and the = links goes on the phasers aligning with the L on the driver's side and the R on the passenger side. You will probably have to turn the cam some to get the marks to line up. I use a pair of vice grips between the cam lobes to hold the cam. Don't forget to pull the pins out of the tensioner to release it. Double and triple check the mark on the crank it's easy for the chain to slip a tooth while installing it.
  #130
Old 08-10-2018, 01:08 PM
gamboni's Avatar
gamboni
gamboni is offline
OK gotcha? I need to think about this one for a while. I did a prelim test and put the chains on ( Just to see if they line up correctly). They seem to fine but the passenger side chain went on a lot easier then the drivers side and has a lot more slack? Are the chains the same size?
I am so sorry to be this ignorant but "what is the chain arm and pivot?" How do I know when the left side is "verified in time?" Yuk, to be so novice ....a little nervous.
  #131
Old 08-10-2018, 01:26 PM
gamboni's Avatar
gamboni
gamboni is offline
Ok I found a picture from the beginning. Is this correct?
  #132
Old 08-10-2018, 01:46 PM
70f100longbed
  #133
Old 08-10-2018, 01:48 PM
70f100longbed
Thats what im talking about the bump near the pivot. The left arm has it, the right does not. The chains are the same.
  #134
Old 08-10-2018, 02:26 PM
gamboni's Avatar
gamboni
gamboni is offline
Ok, Got it and I assume the guides only go on one way?:The Tensioners are marked L and R so good.
  #135
Old 08-10-2018, 03:18 PM
70f100longbed
Yep the guides only fit one way.
Quick Reply: 05 F-150, 5.4 Lariat Bent Rod #1 cylinder.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
