05 F-150, 5.4 Lariat Bent Rod #1 cylinder. - Page 14 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Reload this Page >
Old 08-18-2018, 03:08 PM
gamboni
gamboni is offline
gamboni is starting off with a positive reputation.
No worries I got it. Timing cover bolts are snug and then snug as a bug good enough. Down to the easy stuff boys going to start this thng tomorrow.Beers are on me.
  #197
Old 08-18-2018, 03:52 PM
1saxman's Avatar
1saxman
1saxman is offline
1saxman has a good reputation on FTE.1saxman has a good reputation on FTE.1saxman has a good reputation on FTE.
Good luck, man, you're going to need it.
  #198
Old 08-18-2018, 06:56 PM
gamboni
gamboni is offline
Nah, I have some Real good support on this forum. It will work fine. I'm on the home stretch now.
  #199
Old 08-18-2018, 07:10 PM
redfishtd
redfishtd is offline
redfishtd is starting off with a positive reputation.
I held back to not put too many cooks in the engine
But when tearing it down a life size card board timing cover is where you put all the hardware and torque specs . I stole this idea from a smart mechanic you can see part of it here along with my homemade crank pulley holding tool . It lists the torque and sequence , a little tape on rear holds bolts . Good luck to us .
  #200
Old 08-19-2018, 08:39 AM
gamboni
gamboni is offline
Thanks Redfish, in the future great idea but a little late now.
  #201
Old 08-19-2018, 10:32 AM
redfishtd
You just never know . But you had a tiger by the tail and moving fast. Gentle men start your engines .
  #202
Old 08-19-2018, 12:08 PM
gamboni
gamboni is offline
I am rfeady to put the fuel rail back on but I am not sure about these Ford Escape 3.0L V6 injectors ....They fit nice, the plug is thye same, they are two hole and have the same spray pattern but I have not been able to verify the part number since the ones from the escape do not have part numbers on them? So, i am scared, I do not want this to happen again. Any advice is aprreciated ..Thanks
Dale
  #203
Old 08-19-2018, 01:21 PM
redfishtd
Motor oil up orings and install in rail put newspaper under
Turn key on -Just to make sure none dripping , I would think it would work . PCM and o2 going to determine pulse width . They should not out perform originals .It would seem to be less performance than anything . But this is over my head . If the flood had not got my old ones I would ship them to you ,they were still good until the salt water got them . . Somebody on here must have changed them out under maint and still have old ones . I'm going to change again in 30k miles or so. I have 70k right now . Didn't you say they were the same resistance same numbers . You must have tested and cleaned them .
  #204
Old 08-19-2018, 02:37 PM
gamboni
gamboni is offline
Yes, I tested and cleaned them and they squirt just fine under pressure. Spay pattern seems indenticle to the originals.
  #205
Old 08-19-2018, 04:23 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
I did some research and from what I can determine they both are 24 lb injectors so they should work just fine. Not sure why they are different part numbers though. Worst that can happen is the check engine light comes on for running lean if they don't flow as much as the originals.
  #206
Old 08-19-2018, 05:21 PM
redfishtd
I knew there was some smarter people out there.I did check rock auto and they were different numbers . I would change them once the engine proves out on down the road. I don't believe in old injectors .
  #207
Old 08-19-2018, 07:36 PM
gamboni
gamboni is offline
Almost done got the oil pan on had to stop rain rain rain anybody know how to build an ark?Thank you 70 F for your research Iíll go with the injectors hopefully will have this truck started Mid next week
duke38632
1968-2013 Full Size Vans
08-11-2018 08:30 PM
stevetford
08-11-2018 06:57 PM
Quick Reply: 05 F-150, 5.4 Lariat Bent Rod #1 cylinder.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
