05 F-150, 5.4 Lariat Bent Rod #1 cylinder.
#151
Thanks redfish for your input but please dont confuse the situation. Dave, the only way I can think of that would make the chain hit the vct is if the cams were swapped. I know I said earlier that the left cam was shorter but I found that info on google and havent really been able to confirm it. So what I want you to do is now that the chain is off look down the phaser at the crank gear and see if they are aligned. Just like looking down a board to see if its straight. Now I'm not so sure if the left cam is the shorter one maybe its the right one thats shorter. The phaser and crank gear should line up exactly.
#152
#153
#154
#155
#156
#157
@70f100longbed, I concur with your assessment that the cams are mounted on the wrong bank - based on the mis-alignment of bank2 phaser gear, (ie: cam being slightly shorter on front.)
This does call into question one important point NOW (mentioned in your post #140 above) on which I disagree.
I believe the keyway is aligned with the crankshaft throw for cylinder 1 and 5. Thus, when the keyway is aligned with center of crankshaft gear and phaser gear (11:00 o'clock), cylinder #1 is at TDC. ??? If this is the case ---- or perhaps under ANY circumstances --- when @gamboni tightened down the cam caps with cams swapped, how can we say what the state of pistons / valves were.
The point here: Is there a simple reliable way we can advise @gamboni to check to make sure no valve / piston contact occurred or valves bent???
#159
That would be true in a perfect world. But the lobes on opposite cams are all scrambled if they are in fact swapped. So, all bets are off. That's the crux of my question to @70f100longbed - readily admitting I am not able to wrap my head around valve location if I split the firing order in half and swapped the halves end to end .... !!!!! ???? (LOL - but I'm really being serious, NOT laughing).
#160
#161
I can't see what could happen in this case
Hopefully the cam journals/ caps are not mixed up also . I always steer people away from left-right to passenger -driver side .
@70f100longbed your knowledge exceeds mine I could not have led him thru all you have done . Let alone the reverse cam lobes . Just haven't had enough of them torn down to this point . Lets hope he is still okay . If he stayed at/near six oclock on timing dot with crank . He has done an intense remarkable deep job- a lot to get his head around .
#162
@ Redifish Thanks for the compliment, it's not too bad, I have some mechanical skills. But yes I did get the caps all mixed up but I figured it out. I don't know if you all know this but I was looking at the caps and the cam shaft under magnification to try an match groves like on Forensic files. I noticed on the top of the caps is a very small ( very small you got to wipe it off to see it) engraving showing which cylinder the caps go on and in which way they face. When I saw this it was almost orgasmic "well not quite". So I took a picture of both and I think the engraving is exactly spot on. This picture below is from the # 4 cylinder end cap. I think they match and all the others did also.
#163
Those lines are exactly why the caps shouldn't get mixed up each bearing surfaces has a unique wear pattern and mixing them up causes the cam to make new patterns which wears out the surfaces more plus each cap is machined to it's respective spot on the head and mixing them up causes the surfaces to not align exactly. Might be off a half thousandth from being round doesn't sound like a lot but it is in these close tolerance engines
#164
#165
@70F Thank you, we are back on track. Got the cams reversed yesterday. All lines are good now. Going to time the drivers side tonight.
@redfish yes the caps are engraved (but you can tell its by hand) so ya maybe, at some point, they did have to take it apart at the factory. I'll send a picture definelty a tiny engraver
