Removing split beam nuts from shock mounts...
Old 06-09-2018, 05:38 PM
JakRak's Avatar
JakRak
JakRak is offline
Since I've got the bed wood out of the truck, I thought it would be a good time to put in new rear shocks. Should be an easy job, right?
Well, after dozens of soakings with PB Blaster over the past three days, and even a few heat sessions with the torch, I cannot get the nuts off. I've got a few turns on one of them, but they are the old split beam/split hex nuts and they are holding on tight. Right now I'm working on the top side, and of course, one of them is spinning in the hole in the frame. The bottom nuts (axle side) are really rusty and I've taken to soaking them in acetone/ATF mix until I try to put a wrench on them.
Any trick to getting these buggers off, besides gorilla arms and a 3 ft breaker bar?
Old 06-09-2018, 05:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
I'd just use a nut cracker, or a torch, or drill them on a flat then split them.
Old 06-09-2018, 06:41 PM
JakRak's Avatar
JakRak
JakRak is offline
Or you can try the wrench "just one more time" and snap the stud off, like an idiot...
New upper rear shock mounts, anyone?
Old 06-09-2018, 09:21 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C = F100; D = F250; J = P350; Y = F350:
34449-S7 .. Nut - 1/2" -20 / Obsolete
I found (67) 34449-S78 .. but I'm not sure if this is the same nut.
Old 06-09-2018, 09:31 PM
JakRak's Avatar
JakRak
JakRak is offline
Thanks, Bill. I think what I need is #18196, the shock mount itself, since I sheared off the stud.
Oddly enough, all the bolts came off the other three points without a hitch, so I only broke the one.
Old 06-09-2018, 10:03 PM
NumberDummy
TAAA-18196-A .. Rear Shock Absorber to Frame Upper Stud / Obsolete
1953/55 F100/250 & P350.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 5 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 6 = 800-543-4959.
OBSOLETE RELIABLE PARTS in Nashville GA has 7 = 229-686-5101.
Old 06-09-2018, 11:20 PM
Hotrod350's Avatar
Hotrod350
Hotrod350 is offline
I use gorilla arms and a 2.5 foot breaker bar. It kinda scares me, because all of these types of nuts I have gotten off pretty easily.
Old 06-11-2018, 02:44 AM
TitusDH's Avatar
TitusDH
TitusDH is offline
This is very strange. No rust and the threads look perfect. Maybe someone put locktite on the stud prior to assembly. But that should have softened with heat?
I unscrewed mine simply with a relatively short wrench - hardly 8 inch in length.
Old 06-11-2018, 07:01 PM
JakRak's Avatar
JakRak
JakRak is offline
I treated the hell out of all the nuts with PB Blaster and heat for a few days. I wire brushed all the crud off the nuts and bolt threads as best I could before I even put a wrench on there. Only one snapped. The other three spun off easily with minimal pressure, even the bottom ones, which were in worse shape. I'm going to guess that one nut got rusted really tight on the mount, and my enthusiastic efforts with the breaker bar caused it to snap. It could have been worse - I could have snapped off ALL of them.
Old 06-12-2018, 06:08 PM
CBeav's Avatar
CBeav
CBeav is offline
If only the thread snapped, grind the end flat, drill, tap and thread for a bolt.
Old 06-15-2018, 12:57 PM
JakRak's Avatar
JakRak
JakRak is offline
That's actually a good workaround, but the previous owner left me with a box of spare parts, which included a set of brand new shock mounts (which is one reason I wasn't too bummed when I snapped that stud off). They went in without a hitch and the new shocks are mounted up.
ajsemtb
04-12-2020 10:45 PM
mlis
13
08-12-2015 11:02 AM
niveknonrev
05-22-2015 08:31 PM
fxstb
1997 - 2003 F150
06-25-2014 02:14 PM
atrmg1610
1999 to 2016 Super Duty
16
11-11-2008 08:17 PM
Quick Reply: Removing split beam nuts from shock mounts...
