20x9 +1 wheels, 35x12.50r20 tires pics - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 06-13-2018, 10:57 AM
TXSD6.2
TXSD6.2 is offline
TXSD6.2 is starting off with a positive reputation.
I just ordered some Fuel 20x9 +1 wheels and 35x12.50r20 Nitto Ridge Grapplers for my 2018 F250 crew cab.
I'm pretty sure it will result in the stance I want (slight tire poke from wheel well, obvious difference from stock tucked look but nothing crazy or roller skate looking). Any side/tire poke pics of setups with these dimension wheels/tires would be appreciated!
I intend to throw them on this weekend and run them at stock height until I can get the truck leveled with a readylift 2.5" in a few weeks. I've seen a lot of info that says this is doable.
Old 06-13-2018, 12:36 PM
pezracer's Avatar
pezracer
pezracer is offline
pezracer is starting off with a positive reputation.
My local guy screwed up and ordered +1 and I used them for about a week until my +20 wheels came in. I believe you should have gone +20, they are just right, and no rubbing. The +1 will stick out much more then you think. I have the same tires as well.
Old 06-13-2018, 02:36 PM
TXSD6.2
TXSD6.2 is offline
Thanks, pezracer
Do you have any pics of yours with the 20x9 +20 and the 35x12.50 Ridge Grapplers?
Old 06-13-2018, 02:42 PM
pezracer's Avatar
pezracer
pezracer is offline
This is a Fuel Maverick 20x9 with +20 offset with 35 Nitto Ridge Grapplers, stock suspension, no leveling kit and no rubbing. Even with the +20, they still stick out of the fenders nicely, but the +1 stuck out too much in my opinion.
Old 06-13-2018, 02:53 PM
tpalmer007
tpalmer007 is offline
tpalmer007 is starting off with a positive reputation.
20x9 +1 Fuel Vapor 35x12.5x20 Ridge Grapplers
Old 06-13-2018, 03:19 PM
pezracer's Avatar
pezracer
pezracer is offline
I believe the difference in offset between +1 and +20 is less then 1”, so you’ll be fine with either, but given the choice and having had both on my truck, I much preferred the +20 being in more. Good luck, I put a lot of research into it before I settled on what I have and I’m really happy.
Old 06-13-2018, 03:24 PM
jakematic's Avatar
jakematic
jakematic is offline
jakematic is starting off with a positive reputation.
Thanks
Thanks guys for the thread and the pictures - is nice to see what they look like.
I'm also not interested in leveling, and this has been invaluable.
My brain checks out when it comes to these wheel & tire numbers !
Old 06-13-2018, 03:39 PM
TXSD6.2
TXSD6.2 is offline
Thanks guys!
The difference is pretty small between the two. The +1's above look great too. I went ahead and changed my order for the +20 just to be safe instead of wishing I had.
Old 06-13-2018, 03:43 PM
TXSD6.2
TXSD6.2 is offline
Tpalmer,
Do you have fender flares?
Old 06-13-2018, 03:46 PM
tpalmer007
Originally Posted by TXSD6.2 View Post
Tpalmer,
Yep. Had them put on about a month ago. Bushwacker OEM style painted body color- white platinum.
Old 06-13-2018, 04:02 PM
Deadbuck
Deadbuck is offline
Deadbuck is starting off with a positive reputation.
Difference between +1 and +20 is 3/4”. I had +20 on my 17 and they fit perfect. I wouldn’t do +1 unless that was the only option. I did 35” also with stock height and no rub, then went with 2.5” readylift because it looked goofy with stock height
Old 06-13-2018, 04:24 PM
Casey Nelson's Avatar
Casey Nelson
Casey Nelson is offline
Casey Nelson is starting off with a positive reputation.
My wheels are fuel Mavericks 20x9, +01m offset with toyo mts 35x12.50. I’m glad I went with that instead of the +20. No rubbing at all with 2.5 level, not even when the suspension flexs
Old 06-13-2018, 05:18 PM
pezracer's Avatar
pezracer
pezracer is offline
Nice taste in trucks and wheels Casey! I have no rubbing either with my +20s, with no leveling, and at full lock and flexing.
Old 06-13-2018, 05:30 PM
Casey Nelson
Thanks! When I saw your truck I thought the same thing! Lookin sharp!
Old 08-11-2018, 10:06 AM
texasjonathan
texasjonathan is offline
texasjonathan is starting off with a positive reputation.
I know this thread is a little old but pezracer can you post a picture looking down the side of your truck? I think you have the setup I want, just need to see how far they stick out.
Quick Reply: 20x9 +1 wheels, 35x12.50r20 tires pics
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
