exhaust manifolds
Old 12-09-2003, 08:26 PM
56f600's Avatar
56f600
56f600 is offline
exhaust manifolds
My '37 has two different type of exhaust manifolds. One side dumps straight down on the front end of the engine. The other side dumps at an angle about a third of the way back. This side is aimed right at frame. The truck came with no other exhaust and I'm wondering what I've got. Ideally a mirror image to the front dump would work good for routing the new exhaust. Any suggestions?
Old 12-11-2003, 05:57 AM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
Check out the site below
I'm not up on the early engines, but what you described sounds about right.
There are diagrams of all flatmotors and associated parts
http://www.vanpeltsales.com/FH_web/flathead_home.htm
Old 12-18-2003, 06:19 AM
Steve_B's Avatar
Steve_B
Steve_B is offline
Hi Mark
What you have is the standard setup
The pipe from 1 side comes under the front of the engine then meets the pipe from the other side before exiting via a single pipe
I have the same but my truck is right hand drive so the opposite way around, I got a pair of left hand drive manifolds so will have a matched pair for a twin exhaust system
Maybe you could find a right hand drive manifold
Stephen
Slyhuntr
09-22-2015 09:11 PM
jarrettseiple
06-14-2015 09:58 PM
arvet19
Large Truck
04-10-2015 02:55 PM
phroldschool
11-13-2014 05:14 PM
fordtruckfan90
Modular V8 (4.6L, 5.4L)
06-23-2005 05:58 PM
Quick Reply: exhaust manifolds
