No click, no crank no start - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-12-2018, 11:34 PM
Krdiesel06
Krdiesel06 is offline
Krdiesel06 is starting off with a positive reputation.
05 f350 6.0 4x4
no click
No crank
no fuel pump sound or fuel injector buzz. No lights on dash and won't connect to scanner or diagnostics scanner .
Pcm good,ficm good, no frayed wires and all fuses and relays good. Fuse box and wires behind fuse box good. Ignition switch is good however if you have a good running 6.0 and unplug your ignitiom switch you will have my same symptoms.
Has aftermarket alarm.
And was leaning to finding out to disable it if indeed it may have enabled and shut down. Or any other pointers would be good.
Already checked wiring and fan plug.
Old 06-13-2018, 04:11 AM
seville009
seville009 is offline
seville009 is gaining momentum as a positive member of FTE.seville009 is gaining momentum as a positive member of FTE.
You donít mention the battery, so have to ask - did you check that?
Old 06-13-2018, 09:57 AM
Krdiesel06
Batteries and connections good
Yes. Batteries good, all connections are good.
Old 06-13-2018, 10:10 AM
DogRidesInBack's Avatar
DogRidesInBack
DogRidesInBack is offline
DogRidesInBack is gaining momentum as a positive member of FTE.DogRidesInBack is gaining momentum as a positive member of FTE.
Alarm system sounds like a good bet.
Hopefully you have documentation, and can determine that you do have power into it where it should be hot and no power coming out where it should. And verify its grounds too as that could also prevent it from releasing.
Old 06-13-2018, 11:12 AM
Krdiesel06
Removing and replacing alarm.
I wonder if having the alarm professionally removed and installed a new alarm fix my problem. I've lived literally ruled out everything but.
Old 06-13-2018, 11:13 AM
Krdiesel06
[QUOTE=Krdiesel06;18034676]I wonder if having the alarm professionally removed and installed a new alarm fix my problem. I've lived literally ruled out everything but. I've heard one person say that his wires on the tow haul on the shifter have caused problems before will check those bars before I get someone out here for the alarm/QUOTE]
Old 06-13-2018, 01:41 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Does it spin over on the bypass wire? That will at least rule out mechanical issues, and narrow it down to where the problem is mostly likely somewhere in the PCM/alarm wiring harness.
Old 06-13-2018, 01:47 PM
Krdiesel06
Starter spins
Yes. Starter works with lead wire and PCM is good it starts my other truck just fine and so does the ficm on my other truck. I've disconnected my fuse box on my other good truck and put the fuse box in this truck and it makes no difference. If you unplug the ignition switch you will have the same symptoms I do on the truck that's not running. Once you unplugged the ignition switch you will see that you get no lights on the dash no click no crank no scanner connection. So I've narrowed it down to either a wire coming from or to the ignition switch that is not getting power or ground whether it be the alarm I don't know.
Old 06-13-2018, 02:42 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
put a code scanner on it and check for codes.
I had this exact problem on my 6.4 and the scanner said open on egt#3. I went down and checked it and the connector somehow came off. had to plug it back in, then run the codes clear button on my scanner. not saying yours is also egt#3, just saying get a code scanner and check your codes.
Old 06-13-2018, 03:18 PM
Krdiesel06
Can not connect
Truck scan gauge. Scanner can not connect nor can the snap on scanner
Old 06-13-2018, 03:48 PM
DogRidesInBack
Do they work on your other truck? And I'm assuming the two trucks are very similar.
Old 06-13-2018, 07:03 PM
Krdiesel06
Yes
Yes trucks are the same. Scanners work on the good truck .until I unplug ignition switch. Then I get same symptoms.
Old 06-13-2018, 07:44 PM
DogRidesInBack
I would still get out my voltmeter and verify it is the alarm system.
If so, assuming you can find the installation instructions on-line, cut it out and jumper around it.
Old 06-20-2018, 12:17 AM
Krdiesel06
Solved
We have owned this truck almost 4 yrs now. I removed the crappy spider web of an alarm and noticed that there were wires tied into the fuse box plugs in back of fuse box. More specifically a wire tied into the relay wire on #302 . Followed it to a toggle switch well hidden and bypassed the switch and it turned on the dash lights and all components(fuel injectors buzzed and fuel pump sounded off) Truck finally fired up. Guess it was in the on position this whole time and finally failed taking us for a loop because we didn't even know it existed.
Old 06-20-2018, 12:41 PM
leardvr's Avatar
leardvr
leardvr is offline
leardvr is starting off with a positive reputation.
Have you had any issues prior - like the c/c not working, the wipers only working on high, or windows some times not working? I ask because my 6.8L did similar type things and is was the fuse block under the dash itself. It looked good but when I pulled it out it was full of water and had shorted out. The final blow was when the truck started cranking on its own with out the key in the ignition. I do not have any alarm systems. Just my $.02
There are post on here about leaky windshield syndrome.
Quick Reply: No click, no crank no start
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
