Widow Makers
Widow Makers
I have a question about widow Maker tires. Since I got my truck I assumed that the tires were widow Makers and I works have to replace them. But i was working under my truck and saw that the tire was marked "tubeless steel belted radial" I thought widow Makers (and all Multi part tires) were tubed tires.
Is there anyway to know without taking them apart? Is there danger about widow Maker tires during inflation/deflation or can they fail at anytime?
Wow! Quite the setup you have there. None of the wheels I see pictured are widow-makers, instead, they are the lock ring type. One of them appears to be damaged though. These wheels are still considered serviceable, BUT with the correct tire. Your tubeless tires obviously have tubes in them.
Hopefully Truckdog will be along shortly to get you squared away.
Might help to know what truck we're looking at, and where you're located. Might be someone local to you that can help. Update your user CP.
Yeah, there is no such thing as a “widow maker” tire. The rims the tires mount on can be either the Firestone RH-5°, called the widow maker, or any of a variety of locking side ring rim designs. The ones you have pictured are locking side ring style. You would be wise to verify that the ones we can’t see are the same. Below is the RH-5° widow maker.
widow maker
https://www.wheels.ca/news/installin...angerous-move/
tires
Back in the day I did a lot of stupid things too, but not that.
Below are the four mounted tires the two unmounted ones are behind a pile of boxes
Driver front
Driver rear
Passenger rear
Passenger front
You have 16 inch wheels on your 55 F350. Before I bought my 55 F350 I asked Stu about the wheels on it. I wasn't going to buy the truck if it had widow makers. He told me there are not and were not any 16 inch Widow Makers. So you're in the c!ear.
But it looks like you need a couple of new wheel studs.
My "New" F5
Hey Guys. I just purchased a 1948/49 F5. I read a good bit online before the purchase about the rims. All that said, I was not sure whether my "new" truck wheels are of the widow maker type. Am I reading Stu's info correct that if the rims measure 22.5", that they are tubeless one piece wheels, not the tube, 2 piece "widow makers?" All the wheels on this F5 I have measure 22.5" if I measured right. I'm new to these trucks and may have misinterpreted the literature out there or measured wrong. I'm just not sure. Here's are pics of both the front and back wheels. Thanks in advance for any help you can provide.
Matt
Front Wheel
Back Wheel
Matt
Front Wheel
Back Wheel
But you have to show us pictures of the truck. Maybe start a new thread .
Thanks for the welcome. I am hoping to finish up the 1960 F100 I'm working on in the next couple months and then I need to figure out what to do with F5. The cab of the F5 was too clean (for a 70 year old truck) for me to pass up. Thankfully my better half was "okay" with this purchase. I am worried about the wheel issue from a cost standpoint. I need to find replacement wheels or decide on an acceptable axle swap. I'm in Iowa if someone reasonably close has leads. I'm open to options and ideas.
