frontend creaking
I've read the posts on the forum about suspensions, creaking, ball joints, sway arms, etc. But I still don't know what to do about it. I, too, was told that the entire control arm needs to be replaced to fix any linage/ball joint problems. But I was also told the control arm would need to be replaced just to rplace the tie rods, which wasn't true.
Any help would be appreciated. I feel like I keep throwing $ at this thing and it still continues to be a problem.
Jess
Five years old is a little too soon to be having to suspect suspension bushings, unless the environment and type terrain mostly traveled is harsher than average.
You said the "SWAY ARM" bushing was replaced. If you mean the (right?) axle beam "pivot bushing", a job that usually requires specialized tools, you already did what I was going to suggest first investigating. If not, then check it out. All other conditions being normal, premature failure could most likely be attributed to engine oil contamination, so keep that in mind when your looking.
The Twin I-Beam axles also have trailing links called Radius Arms, which also have bushing at their rear pivots, that can also disintegrate due to oil or ozone exposure and/or hard use.
You commented on forums discussing 'creaking, ball joints'. You didn't indicate whether that's been looked into or replaced, so I'd have to put that on the list of items to check, too.
Finally, look for signs of mechanical binding or abnormal friction with or around the steering linkage tie-rod adjuster clamps, Pitman Arm (that crank arm on the steering gear box), and areas where (oversized?) tires might be making contact with nearby related components.
Bare metal and/or rust trails or "halos" are usually reliable signs of possible abnormal contact and/or stress cracking is occuring, and well worth further investigation.
Let us know what you find out!
The good news is that there is no problem in handling. No shimmy or pulling or any other symptoms of front end problems. Maybe that's not such good news. If I had one of those problems at least I would know where to look.
If anyone has a solution I'd love to hear it.
