Tow/haul lamp flashing
Yesterday I got new tires put on and the shop rang to say they had the tow/haul lamp flashing. When I looked I also saw the transmission temp gauge was reading 0. Looked underneath and I've got a leak. Obvious thing was to put some more oil in and the lamp went out. Shifts were harder the 1/2 mile I drove before filling.
Not far into the 200 mile trip back home hauling a small trailer, maybe 4000lb, the lamp comes on again, gauge goes back down to 0. Shifts stay good. Had the wife meet me about 30 miles out with some more oil, but this time the tow/haul stayed on. Shifts stayed good. Pulled the following codes:
P0713-FF
P0336-60
P0341-60
U2023-60
So it looks to me like there's a cabling/voltage issue here, and this is the first thing I will check, together with where the leak is coming from. I will also look up what is common to them all - they were the only 4 codes I had and they all come back when deleted.
I will post updates, but if there is something obvious that has escaped me - searching with the iPhone not easy - please don't hold back!
P0713-FF
P0336-60
P0341-60
U2023-60
Forgot to mention that I got a check gauges warning on the dash whenever the tow/haul came on.
Today: looked under the truck, no drips. Cleaned underneath with brake cleaner so I can see where oil is coming from. Turned key and the the trans temp gauge moved - good sign! Fired up, no alarms. Same 4 codes, delete them and Forscan crashes big time. Spend the next 5 mins trying to get it going again, motor idling, following 5 mins shunting the trailer, then check the oil level. It's a bit low. Put a quart in, now good, still no problems. Turn off, look underneath, no oil yet.
So was it low oil on a hot day (Oil smells and looks good), intermittent fault, or I got a visit from the Ford fairy?
The transmission fluid temperature (TFT) sensor has been a problem in these transmissions. Your symptoms (except for the leak) fit that exactly. The sensor is located inside the pan on the solenoid body. The internal harness is sometimes the problem, but usually, it's the sensor itself.
Low oil and the hot day didn't have anything to do with the P0713 code. I don't know anything about the other codes.
Don't waste the money on a fancy pan -- few people will see it and it doesn't do anything for cooling. Just get the 6.4 pan and 6.4 internal filter -- best upgrade for the bux. And, I too would be willing to bring it over to you! Hell, you buy the plane tix and I'll even pay for the pan/filter and help put it on!
Let's see Sean one-up me on that...
Scott
Scott
What oil would you be bringing...? LV, SP, Maxlife?
It could make a difference... But you win, I wasn't going to bring the temp sensor...
I need an airline job and you'd both be over here already, suitcases dripping with best LV ?
Sensor has cleared customs, be nice if it arrived today as it's a job that's much nicer when the sun is shining 😎
Thinking about these offers, anybody taking a trip to northern France is welcome to bring bits over that I need, guaranteed a big welcome and good bed!
