Opinions on this 6 position chip - Ford Truck Enthusiasts Forums
Old 06-10-2018, 02:17 AM
StrokinHer01's Avatar
StrokinHer01
StrokinHer01 is offline
StrokinHer01 is starting off with a positive reputation.
Old 06-10-2018, 02:49 AM
Wesley Green's Avatar
Wesley Green
Wesley Green is online now
Wesley Green has a good reputation on FTE.Wesley Green has a good reputation on FTE.Wesley Green has a good reputation on FTE.
I'll share my experience on it.
Before you order, pull your pcm and get the codes off it to send them that info, you have to pull it to install it anyways, might as well have some experience at it before it's all excitement and adrenaline installing the chip. Year and auto or manual isn't really enough and is hit or miss since there are so many pcm combinations possible. Was a big miss on mine, ( threw SES light and limp mode) had to ship it back after they guessed the wrong pcm codes and added an extra 3 months of unneeded hassle and spousal frustration to the experience.
It adds power but with stock injectors and an upgraded stock turbo above the 50 and 75hp setting you'll look like a crappy Dodge bellowing smoke with no real improvement on power above the 50 & 75 setting. I got GearHead tunes on the same type of chip after a year of the "TS" canned tunes. Vastly different tuning but your preferences may be different than mine. If you want GH get it thru their site vs buying one then having them burn it, it's cheaper.
GH has waay less smoke in the top 3 settings than TS, but the TS tunes spool up the turbo waay faster, better mileage with all the GH tunes vs TS
A stoplight warrior that likes rolling coal and turbo whine will love the TS more than GH tunes, if you tow and want better mileage go with Gearhead.
Gearhead tunes costs more but after comparing them both Gearhead fits my driving needs vs cool kid wants better. But the TS tunes sure were fun to spool up the turbo with
Obviusly an EGT guage is first
edit: Forgot to mention if you ever do any troubleshooting or logging with Forscan or torque pro with TS tunes MAKE SURE you either remove the chip or at least put it in the stock setting. Every click of the **** makes the MAP read about 1 psi less even with the engine off, and made the air intake temp read below freezing. Took me a while to figure out why my MAP was reading 10.4 with the engine off vs my altitudes normal 14.4 , and torquepro would warn me of icy road conditions in the heat of summer
Old 06-10-2018, 08:56 AM
Walleye Hunter
Walleye Hunter is online now
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
Do you have to pull the PCM to get the pertinent data? ForScan reads a lot of that stuff.
Old 06-10-2018, 09:47 AM
Wesley Green
I think your right, I want to say it says the computer code, but I haven't needed to use Forscan for so many months I can't remember 100%
Old 06-13-2018, 05:54 PM
brian42's Avatar
brian42
brian42 is online now
brian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud of
The PCM code is on the back of the box next to the connection. It is actually viewable with an inspection mirror from under the hood.
IMO you should remove your PCM to make sure you get your PCM code accurately. I read my code withe the PCM installed but had to remove the PCM before I ordered a 6 position chip (years ago). When I saw the PCM code sticker after I removed the unit it was not the same that I wrote down from reading it installed in the truck with the inspection mirror.
I took a picture so never have to remove it to check my PCM code if I ever need it.
Just my .02
ttamwhit
01-11-2010 03:59 PM
loudford
1999 to 2016 Super Duty
13
11-12-2009 07:25 AM
BigHazard
02-21-2007 08:49 AM
Fury
09-12-2006 09:47 AM
danr1
08-25-2006 06:23 AM
Quick Reply: Opinions on this 6 position chip
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
