2006 Ford Expedition will not go into gear
There's an interlock on the gear shifter which unlocks with a solenoid when you depress the brake pedal. Since you don't have battery power, this doesn't work. There is a manual release under the steering column somewhere. Can't say where it is for exactly at the moment, but should be a hole where you poke a screwdriver in to release it.
Kevin Hidden
Escape & Escape Hybrid
04-28-2018 04:46 PM
Sledmamma
10-03-2016 06:01 PM
Mustangking1
11-22-2013 08:33 AM
nofearblackstar
08-17-2009 08:09 AM
