What are known problems E4OD in 96?
Howdy,
The guy that rebuilt mine told me that a whole host of 90's Ford transmissions had front seal problems but the problems were mainly the defective seals when once replaced, solved the problem. He also told me that built right, the E4OD is as good as any of them.
Mine was in a 1994 F450 and the previous owner told me that it leaked for a long time. It wasn't excessive, just a nuisance. He routinely operated with a 20,000lb GCVW and it never failed him. That's why I chose it for my 55 F600
Regards,
Rick
Regards,
Rick
I guess I'll just buy one of them and see if I can press it into the hole!
Thank you guys for the info. Years ago when I had the transmission out to do an engine change the torque converter looked like it was new since it was painted blue, and fairly clean so I just left it as is. So far no problems. The reason I asked about the solenoids is because I read on here some place about a guy wiring in a switch to activate the TC clutch, I know that would be a no no with PWM solenoids, anyway I liked his idea to do that.
I was under the impression that they were much lower resistance than the non pwm ones. That means direct constant 12v current would heat them up and burn them out. I don't know that for sure. But I did find out that yes they are non pwm for 96 E4OD. So direct connection should be just fine.
danlee
10-28-2017 09:53 PM
andy80
04-11-2016 08:21 AM
NotEnoughTrucks2014
06-16-2014 08:37 AM
olending
11-19-2007 07:11 AM
