Alright I got a 1997 f350 CCLB. I am having issues with it stalling out on me, I wish I could say it was my driving and me stalling it but it is an automatic. It seems to do it after I hit a bump or turn a corner or uphill stops. For example I was driving it today hit the train tracks and saw the volt meter jump, got to the red light when stopping I noticed the truck stalled out. Started it back up in Nuetral put it in drive and it stalled out again. Started it back up for the second time put it in 2 and it didn't stall. Another time I was stopped at a stop sign uphill and went to give it gas and it started to go but then it stalled out and had the same issue to get it going again. It doesn't have any issue firing back up. The truck does have bigger injectors in it and a bigger turbo it also has a built transmission with under 15,000km, I'm not sure if any of this would effect it or not. Thanks for the help.
no check engine light when it stalls just no warning she's off volt meter will flicker abit and that's about it. No warning usually happens when turning or after hitting a bigger bump
Did you put a Ford or International CPS in? Also check your four valve cover harness's for burnt pins.
i have personally never put a cps in it, I'm not sure if that is something the previous owner did or not, I will look at that though and check those points as well
