Removal of Decals and Adhessive from Govt Van - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > 1968-2013 Full Size Vans
Reload this Page >
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 06-06-2018, 03:31 PM
wcwinans's Avatar
wcwinans
wcwinans is offline
wcwinans is starting off with a positive reputation.
Hey FTE,
I have a government surplus van that still has some of the decal adhesive
you can see the Engineering lettering outline here
on it and i cant remove it. I've tried carb cleaner and goo b gone. Any suggestions?
Old 06-06-2018, 03:58 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.
Gasoline. I used gasoline and a razor blade to gently scrape it. I scratched it up quite a bit at first but after I got a good technique I wasnít even scratching the paint while doing it. Once the heavy stuff is gone, you just use gasoline and cotton cloth. Turning frequently.
Old 06-06-2018, 04:29 PM
Conanski's Avatar
Conanski
Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Goo B Gone or something similar will soften it enough to be scraped off with a razor, also try heating it up with a hair dryer or heat gun if you have one.. it helps. I used one of those paint scraping handles with blades available at Home Depot, much easier on the hands. My truck was owned by a glass company before I got it so both sides and the rear doors were covered with decals, took me several days to get them all off. Final cleanup with Varsol will take off everything left after the heavy scraping.
Old 06-06-2018, 08:31 PM
EagleFreek's Avatar
EagleFreek
EagleFreek is offline
EagleFreek is starting off with a positive reputation.
A decal eraser wheel may work. They usually work better when the decal is in tact, though. Using chemicals, you risk damaging the paint. I've used these mulitple times over the years and they do the best job in my opinion. I only had a problem one time where it went through the paint, because it was a poor repair and cheap paint was used. Click on the Amazon link.
Amazon Amazon
Old 06-06-2018, 09:38 PM
wirelessengineer
wirelessengineer is offline
wirelessengineer is starting off with a positive reputation.
Try Bug & Tar remover before you go to the big guns. A blow dryer will soften things without damaging the paint.
Old 06-07-2018, 05:56 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
That electric tool is expensive.
Gasoline wonít hurt your paint. And besides, that 35year old van probably doesnít have great paint finish anyway right ?
I suspect I have the most direct / most recent experience of everyone else on here, regarding sticker removal. Iíve bought and un-stickered three vehicles in the last six months.
Ditch the heat; it just slows down your progress by slightly hurting your fingers.
Grow out your fingernails an extra couple days and use them for sticker removal. The angle of peeling the sticker is most important. Has to be closer to parallel to the body panel. You Natural inclination is to peel it exactly perpendicular but thatís not productive.
After the sticker is gone, use gasoline on the sticker goo. As mentioned above.
I promise you you will like the process.
Old 06-08-2018, 08:00 PM
EagleFreek's Avatar
EagleFreek
Expensive? The eraser wheel is $10. Practically everyone has a drill. I've removed lettering on several vehicles, motorcycles and personal watercraft over the years. The decal eraser is by far the fastest and easiest method.
Old 06-11-2018, 09:45 AM
wcwinans's Avatar
wcwinans
wcwinans is offline
You may not be able to see it in the picture posted but i believe they tried to use a sticker removal tool. there was a chunk of paint taken out of the bottom left of the engineering sticker.
So far, I have tried carb cleaner and goo be gone with a credit card to scrape away. ALL the other stickers came off and are cleaned up nicely. I don't know what they did to this sticker, but the outline that's dark is what is left and that stuff is DRY and very stubborn.
Do you think light sandpaper is a good idea?? I'll have to try the gasoline option too.
Old 06-11-2018, 10:51 AM
GreeVan's Avatar
GreeVan
GreeVan is offline
GreeVan is starting off with a positive reputation.
No.
Before sand paper, I'll try tooth paste. It is indeed a light abrasive. If you want a little bit more abrasiveness there are several grades of polishing paste.
Old 06-11-2018, 07:39 PM
Rick1025
Rick1025 is offline
Rick1025 is starting off with a positive reputation.
3M makes a "wood grain" removal spray.Also,try soaking with WD40.With any luck,the paint underneath will not have a different shade than the original.
Old 06-14-2018, 12:22 PM
CWR032
CWR032 is offline
CWR032 is starting off with a positive reputation.
If there's a lot of adhesive left, the decal eraser tool will get the bulk of it off without hurting the paint. You do need a high speed electric drill since most cordless don't spin fast enough to make the eraser tool work (and it's really hard on a cordless to run a long time).WD-40 will make quick work of whatever gum is left.
Old 06-16-2018, 08:25 PM
wirelessengineer
Sandpaper will just get gummed up.
Old 06-17-2018, 09:36 AM
Nicholas Fluhart's Avatar
Nicholas Fluhart
Nicholas Fluhart is offline
Nicholas Fluhart is starting off with a positive reputation.
One of the services my company offers is graphics for commercial fleets. I use a variety of adhesive removers, some stronger than others, depending on the job and type of paint. You can get them from uscutter.com or signwarehouse.com or wherever. Never use razor blades on paint. In fact, if it's good paint, I'd avoid using the rubber eraser as well unless you plan to buff with compound after because it will haze the clear coat. Since you've already got the graphic itself off, you probably don't need heat. Let the adhesive remover soak for several minutes. Then use a plastic squeegee to carefully rake off the thick goop. If you keep the surface wet with the solvent the less chance of scratching the paint. Repeat the process until you can use a towel to wipe off the residue. Finish with a cleaner like Windex to remove the solvent.
Old 06-17-2018, 04:59 PM
econovanfan1's Avatar
econovanfan1
econovanfan1 is offline
econovanfan1 is starting off with a positive reputation.
I would think a good buffing wheel with some polishing compound would do the trick …. but then you might have to polish the rest of the van to match your new-found shine !!! :lol:
Old 06-18-2018, 07:34 PM
wirelessengineer
Thumbs up
Originally Posted by Nicholas Fluhart View Post
One of the services my company offers is graphics for commercial fleets. I use a variety of adhesive removers, ....
That's the nice thing about forums like this. You always get the usual half-baked opinions, of course, and some solid, informed opinions, and the occasional know-it-all-know-nothing opinion.
But then sometimes you get to hear from someone who really knows what he's talking about.
Quick Reply: Removal of Decals and Adhessive from Govt Van
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
