Removal of Decals and Adhessive from Govt Van
on
Goo B Gone or something similar will soften it enough to be scraped off with a razor, also try heating it up with a hair dryer or heat gun if you have one.. it helps. I used one of those paint scraping handles with blades available at Home Depot, much easier on the hands. My truck was owned by a glass company before I got it so both sides and the rear doors were covered with decals, took me several days to get them all off. Final cleanup with Varsol will take off everything left after the heavy scraping.
A decal eraser wheel may work. They usually work better when the decal is in tact, though. Using chemicals, you risk damaging the paint. I've used these mulitple times over the years and they do the best job in my opinion. I only had a problem one time where it went through the paint, because it was a poor repair and cheap paint was used. Click on the Amazon link.
That electric tool is expensive.
Gasoline won’t hurt your paint. And besides, that 35year old van probably doesn’t have great paint finish anyway right ?
I suspect I have the most direct / most recent experience of everyone else on here, regarding sticker removal. I’ve bought and un-stickered three vehicles in the last six months.
Ditch the heat; it just slows down your progress by slightly hurting your fingers.
Grow out your fingernails an extra couple days and use them for sticker removal. The angle of peeling the sticker is most important. Has to be closer to parallel to the body panel. You Natural inclination is to peel it exactly perpendicular but that’s not productive.
After the sticker is gone, use gasoline on the sticker goo. As mentioned above.
I promise you you will like the process.
You may not be able to see it in the picture posted but i believe they tried to use a sticker removal tool. there was a chunk of paint taken out of the bottom left of the engineering sticker.
So far, I have tried carb cleaner and goo be gone with a credit card to scrape away. ALL the other stickers came off and are cleaned up nicely. I don't know what they did to this sticker, but the outline that's dark is what is left and that stuff is DRY and very stubborn.
Do you think light sandpaper is a good idea?? I'll have to try the gasoline option too.
If there's a lot of adhesive left, the decal eraser tool will get the bulk of it off without hurting the paint. You do need a high speed electric drill since most cordless don't spin fast enough to make the eraser tool work (and it's really hard on a cordless to run a long time).WD-40 will make quick work of whatever gum is left.
One of the services my company offers is graphics for commercial fleets. I use a variety of adhesive removers, some stronger than others, depending on the job and type of paint. You can get them from uscutter.com or signwarehouse.com or wherever. Never use razor blades on paint. In fact, if it's good paint, I'd avoid using the rubber eraser as well unless you plan to buff with compound after because it will haze the clear coat. Since you've already got the graphic itself off, you probably don't need heat. Let the adhesive remover soak for several minutes. Then use a plastic squeegee to carefully rake off the thick goop. If you keep the surface wet with the solvent the less chance of scratching the paint. Repeat the process until you can use a towel to wipe off the residue. Finish with a cleaner like Windex to remove the solvent.
But then sometimes you get to hear from someone who really knows what he's talking about.
